[Qgis-user] ArcGIS Layer File
Andreas Neumann a.neumann at carto.net
Tue Mar 25 10:02:39 PDT 2014
Hi Ross,
You can put the symbol anywhere you like. You specify the root of the
SVG file location in "Settings" -> "Options" -> Tab "System" -> section
"SVG paths". QGIS also comes with some "builtin" SVG files - location
depending on the operating system you use. Once the symbols are found
you can use the categorized renderer in the "Style" section and
graphically assign the SVG symbol with a category.
If you move your project around to different computers just think about
copying these symbols as well and set the SVG paths again at your other
computer.
Hope this helps,
Andreas
Am 25.03.2014 16:44, schrieb Ross Easterling:
> Thanks Carol!
> I've downloaded a set of symbols that I can use (SVG images) and I'm sure that with some help from the list I can get them installed correctly (SVG path question).
> SO, once I get there.  Then, how do I make the text referent "oil well" (as an example) as listed in the Attribute Table connect to the appropriate SVG file to bring that symbol in?
> Can I put a path in an attribute table?
