[Qgis-user] lidar visualization in qgis
    David Fawcett
    david.fawcett at gmail.com
    Wed Mar 26 06:29:42 PDT 2014
The issue with these tools is that (at least last time I looked), some of
these tools can't be used in government or commercial sectors without
additional licensing.  I wasn't able to use the tools via Processing
without obtaining a license from the creator.
http://www.cs.unc.edu/~isenburg/lastools/download/LICENSE.txt
On Tue, Mar 25, 2014 at 3:36 PM, Gino Pirelli <luipir at gmail.com> wrote:
> did you tried LASTools as qgis/processing tool?
> http://rapidlasso.com/
> On 25 March 2014 21:08, antonio valanzano <anvalanz at gmail.com> wrote:
>> I would like to start a discussion about the minimal functionalities that
>> a new lidar plugin or a  core function  should present.
>> Based on my experience the minimal requirements are:
>> - to read data in LAS format
>> - to visualize points based on classification or intensity
>> - to allow the filtering of points based on classification
>> - to allow the selection of points with spatial relationship with other
>> layers
>> - to export filtered points or selected points in LAS format
>> Antonio Valanzano
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140326/45653d73/attachment.html>
