[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
Matt Boyd
mattslists at gmail.com
Wed Mar 26 20:09:17 PDT 2014
Its been a while since I opened a gdb, but.. are you opening an esri file
database or a personal geodatabase?
I'd guess you mean a file geodatabase as those are easily distributed and
you need to specify the directory. I don't recall any additional libraries
I've had to install (at least not for quite a while).
you mention that it doesn't recognise the gdb so it suggests to me you may
not be connecting to it correctly.
Apologies if this is obvious but... see below.
[image: Inline image 1]
On Thu, Mar 27, 2014 at 9:37 AM, cdp <cdaponte at synergyaspen.ca> wrote:
> Hi everyone,
> I've reviewed the details here at OSGEO.org and at stackexchange on what
> needs to be installed (advanced install with appropriate libraries) to
> allow
> me to open a GDB file and the process for loading the vector files. I
> still
> get an error saying that the data is 'not a valid or recognized data
> source'. Can anyone confirm that the latest QGIS dev and GDAL library for
> gdb.?
> Does anyone have a test gdb I can use?
> I'm using the March 25, 2014 downloads of QGIS dev and the gdal libraries
> (64 bit OSGEO4W downloader)
> thanks!
> C
> http://osgeo-org.1560.x6.nabble.com/Problem-opening-GDB-v-10-1-using-QGIS-tp5131380.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140327/63225e39/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140327/63225e39/attachment.png>
