[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
    cdp
    cdaponte at synergyaspen.ca
    Thu Mar 27 08:32:22 PDT 2014
That's the process I used to open the file.  ESRI FileGDB was selected by
default.  Still no luck.
The data is supposed to be an Esri file geodatabase created with ArcGIS
10.1.
The data  is stream network data from the BC provincial government and can
be found at the following FTP location if anyone wants to try it out on
their end (no login info required)
ftp.geobc.gov.bc.ca/pub/outgoing/FWA_Public
There you will find 4 zipped files. Download the smallest of them and let me
know what you find. that should be
FWA_LINEAR_BOUNDARIES_SP.gdb.zip
Alternatively if someone has a test geodatabase that they can post a link to
that they know launches in QGIS, please post the link so I can check my
install.
thanks!!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-opening-GDB-v-10-1-using-QGIS-tp5131380p5131608.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
