[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
Even Rouault even.rouault at mines-paris.org
Thu Mar 27 10:29:54 PDT 2014
Selon Eric Goddard <egoddard1010 at gmail.com>:
> In another thread about QGIS and FileGeodatabases, there is a link to
> the OpenFileGDB driver [1]. It mentions a different type of
> compression that the fileGDB API doesn't support. It doesn't appear
> that the FWA_LINEAR_BOUNDARIES_SP.gdb has that type of compression so
> it should be able to load in theory.
No, I don't think so, otherwise (see my previous post) the OpenFileGDB driver
wouldn't open it. I guess the reason is that the database contains a SRS
(projection) that isn't supported by the FileGDB API SDK (it is a common issue
with the SDK).
Even
