[Qgis-user] Problem opening .GDB (v 10.1) using QGIS
    Even Rouault
    even.rouault at mines-paris.org
    Thu Mar 27 10:41:29 PDT 2014
Selon Clifford Snow <clifford at snowandsnow.us>:
> Even,
> How do we get the OpenFileGDB driver?
It is in the development version of GDAL. So for now you have to compile GDAL
from sources. But the development version should be released as GDAL 1.11 within
one month I think. Then the QGIS team will have to catch with it.
Even
> On Thu, Mar 27, 2014 at 10:29 AM, Even Rouault <even.rouault at mines-paris.org
> > wrote:
> > Selon Eric Goddard <egoddard1010 at gmail.com>:
> > > In another thread about QGIS and FileGeodatabases, there is a link to
> > > the OpenFileGDB driver [1]. It mentions a different type of
> > > compression that the fileGDB API doesn't support. It doesn't appear
> > > that the FWA_LINEAR_BOUNDARIES_SP.gdb has that type of compression so
> > > it should be able to load in theory.
> > No, I don't think so, otherwise (see my previous post) the OpenFileGDB
> > driver
> > wouldn't open it. I guess the reason is that the database contains a SRS
> > (projection) that isn't supported by the FileGDB API SDK (it is a common
> > issue
> > with the SDK).
> > Even
> @osm_seattle
> osm_seattle.snowandsnow.us
> OpenStreetMap: Maps with a human touch
