[Qgis-user] How to update the geometry of a table
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Fri Mar 28 01:55:36 PDT 2014
Your GIS layer has only "area" geometry. You need to first extract nodes
(under the same menu) and then add geometry columns.
Cheers,
Saber
-----Original Message-----
From: Rhys A.D. Stewart <rhys.stewart at gmail.com>
To: Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk>
Subject: Re: [Qgis-user] How to update the geometry of a table
Date: Thu, 27 Mar 2014 12:22:58 -0500
Negative, that just adds two columns with area and perimeter to the
layer. I really need a way to update the geometry field. Is that not
possible?
Rhys
Peace & Love|Live Long & Prosper
On Thu, Mar 27, 2014 at 9:44 AM, Saber Razmjooei
<saber.razmjooei at lutraconsulting.co.uk> wrote:
Rhys
From Vector menu > Geometry Tools > Add/Export geometry columns.
Cheers,
Saber
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Rhys
A.D. Stewart
Sent: 27 March 2014 14:24
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] How to update the geometry of a table
Greetings all,
I have a couple hundred rows of a table that I would like to
update with new coordinates, I'm trying to figure out how to do
this in QGIS (i.e. i know i can do this through the sql tool).
I can't see a way to modify the geometry directly in the field
calculator. I'm trying to do this regardless of the layer type .
Regards,
Rhys
________________________________________________________________
This email and any files transmitted with it are confidential
and intended solely for the use of the individual or entity to
whom they are addressed. If you have received this email in
error please notify the system manager. This message contains
confidential information and is intended only for the individual
named. If you are not the named addressee you should not
disseminate, distribute or copy this e-mail. Please notify the
sender immediately by e-mail if you have received this e-mail by
mistake and delete this e-mail from your system. If you are not
the intended recipient you are notified that disclosing,
copying, distributing or taking any action in reliance on the
contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus
transmission, no responsibility for viruses is taken and it is
your responsibility to carry out such checks as you feel
appropriate.
If this email contains a quote or offer to sell products, carry
out work or perform services then our standard terms and
conditions shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
