[Qgis-user] IntraMaps Roam - Linux version
Saulteau Don sault.don at gmail.com
Sat Mar 29 08:47:16 PDT 2014
I'm sure most will figure this out, but it's actually "./build_linux.sh"
for the first script =)
Arch Linux users have to make some minor changes to the scripts because
python is actually a reference to python3 (system default for Arch Linux).
Changing python to python2 in the scripts is good enough. Or they can try
the wiki suggestion
https://wiki.archlinux.org/index.php/python#Dealing_with_version_problem_in_build_scripts
I'll file tickets in the github issue tracker when I find them. Great work
on this project.
Donovan
On Sat, Mar 29, 2014 at 4:39 AM, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey all,
> Just thought I would anyone know who has been following my Roam project
> that I have started to work on making it run in Linux too, and then OS X
> with help.
> You can find the in progress code here:
> https://github.com/NathanW2/Roam/tree/linux
> I'm am not a Linux expert so any help or advice would been welcome.
> Download the source and first run: ./linux_build.sh  You will need the
> PyQt dev tools installed and it assumes QGIS is in /usr/
> After the UI files are built you can run ./run_linux-config.sh to load the
> config manger to create a project and forms.
> Run ./run_linux.sh to launch Roam itself.
> Here is a screenshot from me running it last night on Ubuntu
> http://i.imgur.com/SrBPlai.png
> Most things should work however there might be some stuff that still needs
> updating, I'll fix them as we go.
> Regards,
> Nathan
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140329/a2765190/attachment.html>
