[Qgis-user] Empty Results in R
Filipe Dias
filipesdias at gmail.com
Mon Mar 31 04:07:34 PDT 2014
Im also on Ubuntu 12.04 and tested with R 3.0.1 and R 3.0.3 and it works as
expected.
Have you "upgraded" Processing in the plugin installer? Unfortunately it
install an old and outdated version of the code...
regards
On Mon, Mar 31, 2014 at 11:32 AM, Luis Miguel Royo Pérez <
luis.miguel.royo at gmail.com> wrote:
> Exactly what happened to Paolo,
> <font face="courier">
> <h2> R Output</h2>
> </font>
> or
> <img
> src="/tmp/sextante/rrasterhistogram18a1cdc6d0734098bc728452ee90d3a6.html.png"/>
> Empty outputs. The windows are shown, but the content is none.
> Thank you!!
> El 31/03/14 11:39, Filipe Dias escribió:
> Hi,
> The output of that script should be a window showing you the frequency
> table for the selected field.
> What happens in your case?
> On Mon, Mar 31, 2014 at 7:58 AM, Luis Miguel Royo Pérez <
>> Hi everyone,
>> I'm getting empty results in "R" processes, it's happening the same than
>> this post<http://osgeo-org.1560.x6.nabble.com/SEXTANTE-R-output-td5065333.html>
>> This is what I get in the log:
>> R execution commands
>> options("repos"="http://cran.at.r-project.org/"<http://cran.at.r-project.org/>
>> tryCatch(find.package("rgdal"), error=function(e)
>> install.packages("rgdal", dependencies=TRUE))
>> tryCatch(find.package("raster"), error=function(e)
>> install.packages("raster", dependencies=TRUE))
>> library("raster")
>> library("rgdal")
>> Layer =
>> readOGR("/home/XXXXX/Documentos/Curso_XXXXX/renovacion/cartografia",layer="ciudades_panama")
>> Field="pop_max"
>> table(Layer[[Field]])
>> I'm using:
>> *Ubuntu*: 12.04.4 LTS
>> *QGIS:* 2.2 Valmiera
>> *R:* 3.0.3.20140328
>> I looked for some solution but I didn't find any way. Any help please?
>> Thank you!!
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140331/232ee971/attachment.html>
