[Qgis-user] Empty Results in R
Werner Macho
werner.macho at gmail.com
Mon Mar 31 04:51:33 PDT 2014
Hi!
I recently had the same issue..
I don't know if processing is supposed to install missing module
automatically but the solution for me was to install the missing
packages "rgrdal" and "raster" on my Computer manually..
R
install.packages();
hope this helps
regards
Werner
On 03/31/2014 01:07 PM, Filipe Dias wrote:
> Im also on Ubuntu 12.04 and tested with R 3.0.1 and R 3.0.3 and it
> works as expected.
> Have you "upgraded" Processing in the plugin installer? Unfortunately
> it install an old and outdated version of the code...
> regards
> On Mon, Mar 31, 2014 at 11:32 AM, Luis Miguel Royo Pérez
> <luis.miguel.royo at gmail.com <mailto:luis.miguel.royo at gmail.com>> wrote:
> Exactly what happened to Paolo,
> <font face="courier">
> <h2> R Output</h2>
> </font>
> or
> <img
> src="/tmp/sextante/rrasterhistogram18a1cdc6d0734098bc728452ee90d3a6.html.png"/>
> Empty outputs. The windows are shown, but the content is none.
> Thank you!!
> El 31/03/14 11:39, Filipe Dias escribió:
>> Hi,
>> The output of that script should be a window showing you the
>> frequency table for the selected field.
>> What happens in your case?
>> On Mon, Mar 31, 2014 at 7:58 AM, Luis Miguel Royo Pérez
>> wrote:
>> Hi everyone,
>> I'm getting empty results in "R" processes, it's happening
>> the same than this post
>> <http://osgeo-org.1560.x6.nabble.com/SEXTANTE-R-output-td5065333.html>.
>> This is what I get in the log:
>> R execution commands
>> options("repos"="http://cran.at.r-project.org/"
>> <http://cran.at.r-project.org/>)
>> tryCatch(find.package("rgdal"), error=function(e)
>> install.packages("rgdal", dependencies=TRUE))
>> tryCatch(find.package("raster"), error=function(e)
>> install.packages("raster", dependencies=TRUE))
>> library("raster")
>> library("rgdal")
>> Layer =
>> readOGR("/home/XXXXX/Documentos/Curso_XXXXX/renovacion/cartografia",layer="ciudades_panama")
>> Field="pop_max"
>> table(Layer[[Field]])
>> I'm using:
>> _Ubuntu_: 12.04.4 LTS
>> _QGIS:_ 2.2 Valmiera
>> _R:_ 3.0.3.20140328
>> I looked for some solution but I didn't find any way. Any
>> help please?
>> Thank you!!
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140331/ec107bac/attachment.html>
