[Qgis-user] Empty Results in R
Luis Miguel Royo Pérez
luis.miguel.royo at gmail.com
Mon Mar 31 05:51:14 PDT 2014
After install libproj-dev, I could install those packages and everything
is working fine.
Thanks a lot!!!
El 31/03/14 13:51, Werner Macho escribió:
> Hi!
> I recently had the same issue..
> I don't know if processing is supposed to install missing module
> automatically but the solution for me was to install the missing
> packages "rgrdal" and "raster" on my Computer manually..
> R
> install.packages();
> hope this helps
> regards
> Werner
> On 03/31/2014 01:07 PM, Filipe Dias wrote:
>> Im also on Ubuntu 12.04 and tested with R 3.0.1 and R 3.0.3 and it
>> works as expected.
>> Have you "upgraded" Processing in the plugin installer? Unfortunately
>> it install an old and outdated version of the code...
>> regards
>> On Mon, Mar 31, 2014 at 11:32 AM, Luis Miguel Royo Pérez
>> <luis.miguel.royo at gmail.com <mailto:luis.miguel.royo at gmail.com>> wrote:
>> Exactly what happened to Paolo,
>> <font face="courier">
>> <h2> R Output</h2>
>> </font>
>> or
>> <img
>> src="/tmp/sextante/rrasterhistogram18a1cdc6d0734098bc728452ee90d3a6.html.png"/>
>> Empty outputs. The windows are shown, but the content is none.
>> Thank you!!
>> El 31/03/14 11:39, Filipe Dias escribió:
>>> Hi,
>>> The output of that script should be a window showing you the
>>> frequency table for the selected field.
>>> What happens in your case?
>>> On Mon, Mar 31, 2014 at 7:58 AM, Luis Miguel Royo Pérez
>>> wrote:
>>> Hi everyone,
>>> I'm getting empty results in "R" processes, it's happening
>>> the same than this post
>>> <http://osgeo-org.1560.x6.nabble.com/SEXTANTE-R-output-td5065333.html>.
>>> This is what I get in the log:
>>> R execution commands
>>> options("repos"="http://cran.at.r-project.org/"
>>> <http://cran.at.r-project.org/>)
>>> tryCatch(find.package("rgdal"), error=function(e)
>>> install.packages("rgdal", dependencies=TRUE))
>>> tryCatch(find.package("raster"), error=function(e)
>>> install.packages("raster", dependencies=TRUE))
>>> library("raster")
>>> library("rgdal")
>>> Layer =
>>> readOGR("/home/XXXXX/Documentos/Curso_XXXXX/renovacion/cartografia",layer="ciudades_panama")
>>> Field="pop_max"
>>> table(Layer[[Field]])
>>> I'm using:
>>> _Ubuntu_: 12.04.4 LTS
>>> _QGIS:_ 2.2 Valmiera
>>> _R:_ 3.0.3.20140328
>>> I looked for some solution but I didn't find any way. Any
>>> help please?
>>> Thank you!!
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140331/b41f4758/attachment.html>
