[Qgis-user] Diagrams Not Printing
Langford, Robert Robert.Langford at salford.gov.uk
Mon Mar 31 05:04:43 PDT 2014
All,
I've found a few older reports of this (Bug #4222, #4345, #4486) but can't seem to get to the bottom of it.
Basically I'm trying to add scaled pie chart diagrams to a polygon layer, see test images:
* http://i.imgur.com/7JPPY5S.png - screen grab from the composer
* http://i.imgur.com/NrZ48f3.png - resultant image export
I've tried the both size units of "mm" and "map units", exported as image, SVG, PDF and printed as raster.
I've got the Automated Placement Settings set to include "Show partials labels", "Show all labels and features for all layers" and also "Show candidates".
The only way I've managed to get this to work is by converting the layer to polygon centroids and using the diagrams on the point layer.
I'm on Windows 7 and QGIS version: 2.2.0-Valmiera, QGIS code revision: c3a2817.
Any advice appreciated.
Many thanks,
Rob
DISCLAIMER: The information contained in this communication/message from Robert.Langford at salford.gov.uk sent on Mon Mar 31 13:04:44 2014 is confidential. It is intended solely for the addressee(s) qgis-user at lists.osgeo.org
Access to this message by anyone else is unauthorised. If you are not the intended recipient, any disclosure, copying, or distribution of the message, or any action or omission taken by you in reliance on it, is prohibited and may be unlawful.
As a public body, Salford City Council may be required to disclose this email [or any response to it] under the Freedom of Information Act 2000, unless the information in it is covered by one of the exemptions in the Act.
Please immediately contact the sender, Robert.Langford at salford.gov.uk if you have received this message in error.
For the full disclaimer please access http://www.salford.gov.uk/e-mail.  Thank you.
