[Qgis-user] Diagrams Not Printing
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Mon Mar 31 05:31:31 PDT 2014
Hi Robert,
I have tried with QGIS 2.2 (under windows 7, 64 bit) and could not replicate
your problem.
Could you reproduce those 2 images with the settings below:
Under Position > Automated placement settings:
Search method: Chain (fast)
Number of candidates: set all to 8
Enable:
	Show partials labels
	Show all labels and features for all layers
	Show candidates
	Show shadow rectangles
Cheers,
Saber
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Langford, Robert
Sent: 31 March 2014 13:05
To: 'qgis-user at lists.osgeo.org'
Subject: [Qgis-user] Diagrams Not Printing
All,
I've found a few older reports of this (Bug #4222, #4345, #4486) but can't
seem to get to the bottom of it.
Basically I'm trying to add scaled pie chart diagrams to a polygon layer,
see test images:
* http://i.imgur.com/7JPPY5S.png - screen grab from the composer
* http://i.imgur.com/NrZ48f3.png - resultant image export
I've tried the both size units of "mm" and "map units", exported as image,
SVG, PDF and printed as raster.
I've got the Automated Placement Settings set to include "Show partials
labels", "Show all labels and features for all layers" and also "Show
candidates".
The only way I've managed to get this to work is by converting the layer to
polygon centroids and using the diagrams on the point layer.
I'm on Windows 7 and QGIS version: 2.2.0-Valmiera, QGIS code revision:
c3a2817.
Any advice appreciated.
Many thanks,
Rob
DISCLAIMER: The information contained in this communication/message from
Robert.Langford at salford.gov.uk sent on Mon Mar 31 13:04:44 2014 is
confidential. It is intended solely for the addressee(s)
Access to this message by anyone else is unauthorised. If you are not the
intended recipient, any disclosure, copying, or distribution of the message,
or any action or omission taken by you in reliance on it, is prohibited and
may be unlawful.
As a public body, Salford City Council may be required to disclose this
email [or any response to it] under the Freedom of Information Act 2000,
unless the information in it is covered by one of the exemptions in the Act.
Please immediately contact the sender, Robert.Langford at salford.gov.uk if you
have received this message in error.
For the full disclaimer please access http://www.salford.gov.uk/e-mail.
Thank you.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
