[Qgis-user] Question on Installing a newer version of QGIS
Ramon Andiñach custard at westnet.com.au
Sun Nov 2 01:36:02 PST 2014
If you're using the stand-alone installers (and it sounds like you are) then all the things than QGIS needs (GRASS included) are in the folder for that version.
So there isn't really a preferred way. Uninstall first or later, up to you.
The only major gotchas are:
1. The project files, as no attempt is made for backward compatibility. So, a project saved in 2.6 might not work properly in 2.4 (in this case, I'm pretty sure there will be problems with the composers). Forwards (opening 2.4 projects in 2.6) should work.
2. The settings (and this includes your python plugins) are shared between versions. Mostly this should be fine, but some plugins are quite version specific.
Does that help at all?
FWIW, I (like some other people on this list) have had the development version (which just became 2.6) and 2.4 running side-by-side without major problems.
-ramon.
On 02/11/2014, at 14:35 , Leahy, Thomas A. wrote:
> Hello,
>    Actually I am asking what is the preferred way to upgrade from 2.4 to 2.6?
> Uninstall 2.4 first?
> Would that cause me to loose settings? (Like location of Projects if changed from the default?)
>                    Regards,
>                    Tom
> From: Nadarajah Thirugnanasothy [mailto:vnthiru at yahoo.co.uk]
> Sent: Sunday, November 02, 2014 9:31 AM
> To: Leahy, Thomas A.; qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Question on Installing a newer version of QGIS [*EXTERNAL*]
> Hi,
> How 2.6 installation would effect Grass?
> Thanks
> Thiru
> On Sunday, 2 November 2014, 6:03, "Leahy, Thomas A." <tleahy at bechtel.com> wrote:
> Hello,
>    I wasn’t sure whether the new version 2.6 would install over my old version 2.4 or next to it.
> It turns out it installs next to it and I still have 2.4 installed.  When I am happy with 2.6 can I just uninstall 2.4 or will I need to reinstall 2.6 after uninstalling ver 2.4?
>      Thanks for your assistance.
>                     Regards,
>                     Tom Leahy
