[Qgis-user] QGIS 32 or 64-bit
    Nyall Dawson
    nyall.dawson at gmail.com
    Sun Nov  2 02:26:33 PST 2014
On 2 November 2014 20:48, Lester Anderson <arctica1963 at gmail.com> wrote:
> Hi all,
> Rather basic query, but is there a real advantage of the 64-bit version
> over 32-bit when on say Windows 7/8 ? I use QGIS at home and work, and have
> readily had multiple copies of QGIS running for separate projects and not
> seen any real problems (subject to memory on the system of course).
If you're trying to export large, high resolution compositions, than you'll
have much more luck using a 64 bit build. Otherwise the memory limitations
for 32 bit builds can be restrictive.
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141102/795d63d0/attachment.html>
