[Qgis-user] QGIS 32 or 64-bit
Alex Mandel tech_dev at wildintellect.com
Sun Nov 2 09:27:24 PST 2014
We should be clear in this conversation, all of these recommendations
apply to Windows only and may apply to the current version as later
versions might remove the remaining barriers to full 64 bit for everyone.
Linux - there's no reason to use 32 bit.
Mac - I'm not sure what the builds typically are.
Thanks,
Alex
On 11/02/2014 09:10 AM, Chris Crook wrote:
> On the other hand!  If you do not need to export large high resolution compositions then I'd recommend the 32 bit version, as the python interface used for the plugins can have issues with the 64 bit version (most still work but some do not).
> Chris
> ________________________________________
> From: Nyall Dawson [nyall.dawson at gmail.com]
> Sent: 02 November 2014 23:26
> To: Lester Anderson
> Cc: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] QGIS 32 or 64-bit
> On 2 November 2014 20:48, Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
> Hi all,
> Rather basic query, but is there a real advantage of the 64-bit version over 32-bit when on say Windows 7/8 ? I use QGIS at home and work, and have readily had multiple copies of QGIS running for separate projects and not seen any real problems (subject to memory on the system of course).
> If you're trying to export large, high resolution compositions, than you'll have much more luck using a 64 bit build. Otherwise the memory limitations for 32 bit builds can be restrictive.
> Nyall
> This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
> Qgis-user mailing list
