[Qgis-user] MTR and Postgis - lots of crashes
Andre Joost
andre+joost at nurfuerspam.de
Thu Nov 6 01:55:54 PST 2014
Am 06.11.2014 um 10:43 schrieb Andreas Neumann:
> Hi,
> Am I the only one that still gets a lot of crashes with complex projects
> when the data sources are on Postgis and MTR (parallel rendering in
> multiple cores) is turned on? I get most crashes on Windows, hardly any
> on Linux, but this may be due to the fact that Linux accesses Postgis
> locally, whereas the Win QGIS clients access Postgis remotely. Turning
> off MTR --> no more crashes.
> Is MTR and Postgis working flawlessly for everyone?
> These crashes really annoy me and I have to turn off MTR until these
> problems are fixed.
> Thank you for any hints / sharing your experiences with Postgis and MTR.
Does it help if you use one core less than you have?
I had no crashes with that so far, using 32bit Windows builds.
HTH,
André Joost
