[Qgis-user] Is (or should) composer able to export directly to	postscript ?
    Andrea Peri
    aperi2007 at gmail.com
    Thu Nov  6 13:16:03 PST 2014
I try to export an all vectorial map to SVG format in the composer (qgis 2.6).
When try this appear a windows saying:
>The SVG export function in QGIS has several problems due to bugs and deficiencies in the
>Qt4 svg code. In particular, there are problems with layers not being clipped to the map >bounding box.
>If you require a vector-based output file from Qgis it is suggested that you try printing to
>PostScript if the SVG output is not satisfactory.
I dont find any option to export to postscript from composer.
So my question is to understand if the hint is to install a new
printer postscript driver and use it to redirect the postscirpt to a
file .
Or instead there is a missing option in composer ?
Thx
Andrea Peri
qwerty àèìòù
