[Qgis-user] Is (or should) composer able to export directly to postscript ?
G. Allegri
giohappy at gmail.com
Thu Nov 6 13:53:48 PST 2014
Yes Andrea, the warning should be clearer. Postscript printing requires a
PS driver installed, and it will be available through the print dialog, as
usual.
giovanni
2014-11-06 22:16 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I try to export an all vectorial map to SVG format in the composer (qgis
> 2.6).
> When try this appear a windows saying:
> >The SVG export function in QGIS has several problems due to bugs and
> deficiencies in the
> >Qt4 svg code. In particular, there are problems with layers not being
> clipped to the map >bounding box.
> >If you require a vector-based output file from Qgis it is suggested that
> you try printing to
> >PostScript if the SVG output is not satisfactory.
> I dont find any option to export to postscript from composer.
> So my question is to understand if the hint is to install a new
> printer postscript driver and use it to redirect the postscirpt to a
> file .
> Or instead there is a missing option in composer ?
> Thx
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141106/3bc2fd21/attachment.html>
