[Qgis-user] Quick query re plugins
Lester Anderson
arctica1963 at gmail.com
Mon Nov 10 02:03:07 PST 2014
Hi Nathan,
The old folder for .qgis has the following:
gdal_pam (folder)
python (folder with the plugins)
sextante (folder)
qgis (database file)
symbology-ng-style (XML doc)
.qgis2 is different:
cache (folder)
gdal_pam (folder)
palettes (folder)
processing (folder)
I tried copying the python folder from .qgis to .qgis2 and the plugins show
up when you check the list, but they are all red , with a comment about
missing metadata. Any ideas?
Behind a firewall at work so can't go the normal route for plugins.
Cheers
Lester
On 10 November 2014 09:52, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Lester,
> Any QGIS 2.X version goes into .qgis2 folder with the same setup.
> - Nathan
> On Mon Nov 10 2014 at 7:35:22 PM Lester Anderson <arctica1963 at gmail.com>
> wrote:
>> Hello,
>> If I need to manually install plugins in QGIS 2.6, where do they go? I
>> have the 64-bit version installed.
>> For 1.8 I had to put them in C:\Users\lma\.qgis\python\plugins (32-bit) -
>> QGIS 2.6 does not read this so the installed plugins list is just the
>> default.
>> Cheers
>> Lester
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141110/755e773e/attachment.html>
