[Qgis-user] Quick query re plugins
Nathan Woodrow
madmanwoo at gmail.com
Mon Nov 10 02:04:35 PST 2014
Old 1.8 plugins won't work at all in 2.0. We had a api break.
On Mon, Nov 10, 2014, 8:03 PM Lester Anderson <arctica1963 at gmail.com> wrote:
> Hi Nathan,
> The old folder for .qgis has the following:
> gdal_pam (folder)
> python (folder with the plugins)
> sextante (folder)
> qgis (database file)
> symbology-ng-style (XML doc)
> .qgis2 is different:
> cache (folder)
> gdal_pam (folder)
> palettes (folder)
> processing (folder)
> I tried copying the python folder from .qgis to .qgis2 and the plugins
> show up when you check the list, but they are all red , with a comment
> about missing metadata. Any ideas?
> Behind a firewall at work so can't go the normal route for plugins.
> Cheers
> Lester
> On 10 November 2014 09:52, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>> Hey Lester,
>> Any QGIS 2.X version goes into .qgis2 folder with the same setup.
>> - Nathan
>> On Mon Nov 10 2014 at 7:35:22 PM Lester Anderson <arctica1963 at gmail.com>
>> wrote:
>>> Hello,
>>> If I need to manually install plugins in QGIS 2.6, where do they go? I
>>> have the 64-bit version installed.
>>> For 1.8 I had to put them in C:\Users\lma\.qgis\python\plugins (32-bit)
>>> - QGIS 2.6 does not read this so the installed plugins list is just the
>>> default.
>>> Cheers
>>> Lester
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141110/b4e63bef/attachment.html>
