[Qgis-user] Quick query re plugins
Lester Anderson arctica1963 at gmail.com
Mon Nov 10 02:38:03 PST 2014
Hi Nathan,
OK I have tested a couple plugins (all stated as working for 2.x) but they
do not show up in the manage plugin list:
C:\Users\landerso\.qgis2\python
Copied into python folder: points2one and profiletool - neither shows up.
Is there another folder to put these in?  Not sure what the issue is.
Cheers
Lester
On 10 November 2014 10:21, Lester Anderson <arctica1963 at gmail.com> wrote:
> Cheers Nathan, will have a go and see how I get on
> On 10 November 2014 10:13, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>> Most yes. Will need to check each plugin
>> On Mon, Nov 10, 2014, 8:11 PM Lester Anderson <arctica1963 at gmail.com>
>> wrote:
>>> ok I did not realise that. So will the plugins off
>>> http://plugins.qgis.org/plugins/ work fine in 2.x?
>>> I only have a few key ones I need to work with.
>>> Cheers
>>> On 10 November 2014 10:04, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>> Old 1.8 plugins won't work at all in 2.0. We had a api break.
>>>> On Mon, Nov 10, 2014, 8:03 PM Lester Anderson <arctica1963 at gmail.com>
>>>> wrote:
>>>>> Hi Nathan,
>>>>> The old folder for .qgis has the following:
>>>>> gdal_pam (folder)
>>>>> python (folder with the plugins)
>>>>> sextante (folder)
>>>>> qgis (database file)
>>>>> symbology-ng-style (XML doc)
>>>>> .qgis2 is different:
>>>>> cache (folder)
>>>>> gdal_pam (folder)
>>>>> palettes (folder)
>>>>> processing (folder)
>>>>> I tried copying the python folder from .qgis to .qgis2 and the plugins
>>>>> show up when you check the list, but they are all red , with a comment
>>>>> about missing metadata. Any ideas?
>>>>> Behind a firewall at work so can't go the normal route for plugins.
>>>>> Cheers
>>>>> Lester
>>>>> On 10 November 2014 09:52, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>>> Hey Lester,
>>>>>> Any QGIS 2.X version goes into .qgis2 folder with the same setup.
>>>>>> - Nathan
>>>>>> On Mon Nov 10 2014 at 7:35:22 PM Lester Anderson <
>>>>>>> Hello,
>>>>>>> If I need to manually install plugins in QGIS 2.6, where do they go?
>>>>>>> I have the 64-bit version installed.
>>>>>>> For 1.8 I had to put them in C:\Users\lma\.qgis\python\plugins
>>>>>>> (32-bit) - QGIS 2.6 does not read this so the installed plugins list is
>>>>>>> just the default.
>>>>>>> Cheers
>>>>>>> Lester
>>>>>>> _______________________________________________
>>>>>>> Qgis-user mailing list
>>>>>>> Qgis-user at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141110/6cb5ac7a/attachment.html>
