[Qgis-user] Quick query re plugins
Donald, Nigel Nigel.Donald at doeni.gov.uk
Mon Nov 10 03:37:59 PST 2014
Hi
Try C:\Program Files\QGIS Chugiak\apps\qgis\python\plugins that’s where I have to put mine?
Nigel
Dr Nigel Donald
Hydrology Team
•: 02892 (6)33 475
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Lester Anderson
Sent: 10 November 2014 10:38
To: Nathan Woodrow; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Quick query re plugins
Hi Nathan,
OK I have tested a couple plugins (all stated as working for 2.x) but they do not show up in the manage plugin list:
C:\Users\landerso\.qgis2\python
Copied into python folder: points2one and profiletool - neither shows up.
Is there another folder to put these in?  Not sure what the issue is.
Cheers
Lester
On 10 November 2014 10:21, Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
Cheers Nathan, will have a go and see how I get on
On 10 November 2014 10:13, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Most yes. Will need to check each plugin
On Mon, Nov 10, 2014, 8:11 PM Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
ok I did not realise that. So will the plugins off http://plugins.qgis.org/plugins/ work fine in 2.x?
I only have a few key ones I need to work with.
Cheers
On 10 November 2014 10:04, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Old 1.8 plugins won't work at all in 2.0. We had a api break.
On Mon, Nov 10, 2014, 8:03 PM Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
Hi Nathan,
The old folder for .qgis has the following:
gdal_pam (folder)
python (folder with the plugins)
sextante (folder)
qgis (database file)
symbology-ng-style (XML doc)
.qgis2 is different:
cache (folder)
gdal_pam (folder)
palettes (folder)
processing (folder)
I tried copying the python folder from .qgis to .qgis2 and the plugins show up when you check the list, but they are all red , with a comment about missing metadata. Any ideas?
Behind a firewall at work so can't go the normal route for plugins.
Cheers
Lester
On 10 November 2014 09:52, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Hey Lester,
Any QGIS 2.X version goes into .qgis2 folder with the same setup.
- Nathan
On Mon Nov 10 2014 at 7:35:22 PM Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
Hello,
If I need to manually install plugins in QGIS 2.6, where do they go? I have the 64-bit version installed.
For 1.8 I had to put them in C:\Users\lma\.qgis\python\plugins (32-bit) - QGIS 2.6 does not read this so the installed plugins list is just the default.
Cheers
Lester
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141110/0236d8a1/attachment.html>
