[Qgis-user] Quick query re plugins
Donald, Nigel
Nigel.Donald at doeni.gov.uk
Mon Nov 10 03:50:48 PST 2014
Nathan,
Yes I know what you are saying however this is the path that works as I too have to live with firewalls and restricted access due to security settings ( I have to run as administrator just to save updates to projects)
Nigel
Dr Nigel Donald
Hydrology Team
•: 02892 (6)33 475
From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Sent: 10 November 2014 11:40
To: Donald, Nigel; Lester Anderson; qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Quick query re plugins
> Try C:\Program Files\QGIS Chugiak\apps\qgis\python\plugins that’s where I have to put mine?
No. Never put them there. That is the install folder for qgis and all user plugins should live in .qgis2\python\plugins in your user folder, or else they won't show up when you upgrade to a new version.
- Nathan
On Mon Nov 10 2014 at 9:38:01 PM Donald, Nigel <Nigel.Donald at doeni.gov.uk<mailto:Nigel.Donald at doeni.gov.uk>> wrote:
Hi
Nigel
Dr Nigel Donald
Hydrology Team
•: 02892 (6)33 475
From: qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org> [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] On Behalf Of Lester Anderson
Sent: 10 November 2014 10:38
To: Nathan Woodrow; qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Hi Nathan,
OK I have tested a couple plugins (all stated as working for 2.x) but they do not show up in the manage plugin list:
C:\Users\landerso\.qgis2\python
Copied into python folder: points2one and profiletool - neither shows up.
Is there another folder to put these in? Not sure what the issue is.
Cheers
Lester
On 10 November 2014 10:21, Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
Cheers Nathan, will have a go and see how I get on
On 10 November 2014 10:13, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Most yes. Will need to check each plugin
On Mon, Nov 10, 2014, 8:11 PM Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
ok I did not realise that. So will the plugins off http://plugins.qgis.org/plugins/ work fine in 2.x?
I only have a few key ones I need to work with.
Cheers
On 10 November 2014 10:04, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Old 1.8 plugins won't work at all in 2.0. We had a api break.
On Mon, Nov 10, 2014, 8:03 PM Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
Hi Nathan,
The old folder for .qgis has the following:
gdal_pam (folder)
python (folder with the plugins)
sextante (folder)
qgis (database file)
symbology-ng-style (XML doc)
.qgis2 is different:
cache (folder)
gdal_pam (folder)
palettes (folder)
processing (folder)
I tried copying the python folder from .qgis to .qgis2 and the plugins show up when you check the list, but they are all red , with a comment about missing metadata. Any ideas?
Behind a firewall at work so can't go the normal route for plugins.
Cheers
Lester
On 10 November 2014 09:52, Nathan Woodrow <madmanwoo at gmail.com<mailto:madmanwoo at gmail.com>> wrote:
Hey Lester,
Any QGIS 2.X version goes into .qgis2 folder with the same setup.
- Nathan
On Mon Nov 10 2014 at 7:35:22 PM Lester Anderson <arctica1963 at gmail.com<mailto:arctica1963 at gmail.com>> wrote:
Hello,
If I need to manually install plugins in QGIS 2.6, where do they go? I have the 64-bit version installed.
For 1.8 I had to put them in C:\Users\lma\.qgis\python\plugins (32-bit) - QGIS 2.6 does not read this so the installed plugins list is just the default.
Cheers
Lester
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141110/64ff4988/attachment.html>
