[Qgis-user] Quick query re plugins
Nathan Woodrow
madmanwoo at gmail.com
Mon Nov 10 03:53:16 PST 2014
Hey,
>Yes I know what you are saying however this is the path that works as I
too have to live with firewalls and restricted access due to security
settings ( I have to run as administrator just to save updates to projects)
You should always have access to .qgis2 in your user home as qgis wouldn't
load right without access there. If you have to manual install still
install into there.
You can still do what you want of course but I just don't recommend that as
advice to people because .qgis2 is the right place.
On Mon Nov 10 2014 at 9:50:54 PM Donald, Nigel <Nigel.Donald at doeni.gov.uk>
wrote:
> Nathan,
> Nigel
> Dr Nigel Donald
> Hydrology Team
> (: 02892 (6)33 475
> *From:* Nathan Woodrow [mailto:madmanwoo at gmail.com]
> *Sent:* 10 November 2014 11:40
> *To:* Donald, Nigel; Lester Anderson; qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Quick query re plugins
> > Try C:\Program Files\QGIS Chugiak\apps\qgis\python\plugins that’s where
> I have to put mine?
> No. Never put them there. That is the install folder for qgis and all user
> plugins should live in .qgis2\python\plugins in your user folder, or else
> they won't show up when you upgrade to a new version.
> - Nathan
> On Mon Nov 10 2014 at 9:38:01 PM Donald, Nigel <Nigel.Donald at doeni.gov.uk>
> wrote:
> Hi
> Try C:\Program Files\QGIS Chugiak\apps\qgis\python\plugins that’s where I
> have to put mine?
> Nigel
> Dr Nigel Donald
> Hydrology Team
> (: 02892 (6)33 475
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Lester Anderson
> *Sent:* 10 November 2014 10:38
> *To:* Nathan Woodrow; qgis-user at lists.osgeo.org
> Hi Nathan,
> OK I have tested a couple plugins (all stated as working for 2.x) but they
> do not show up in the manage plugin list:
> C:\Users\landerso\.qgis2\python
> Copied into python folder: points2one and profiletool - neither shows up.
> Is there another folder to put these in? Not sure what the issue is.
> Cheers
> Lester
> On 10 November 2014 10:21, Lester Anderson <arctica1963 at gmail.com> wrote:
> Cheers Nathan, will have a go and see how I get on
> On 10 November 2014 10:13, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Most yes. Will need to check each plugin
> On Mon, Nov 10, 2014, 8:11 PM Lester Anderson <arctica1963 at gmail.com>
> wrote:
> ok I did not realise that. So will the plugins off
> http://plugins.qgis.org/plugins/ work fine in 2.x?
> I only have a few key ones I need to work with.
> Cheers
> On 10 November 2014 10:04, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Old 1.8 plugins won't work at all in 2.0. We had a api break.
> On Mon, Nov 10, 2014, 8:03 PM Lester Anderson <arctica1963 at gmail.com>
> wrote:
> Hi Nathan,
> The old folder for .qgis has the following:
> gdal_pam (folder)
> python (folder with the plugins)
> sextante (folder)
> qgis (database file)
> symbology-ng-style (XML doc)
> .qgis2 is different:
> cache (folder)
> gdal_pam (folder)
> palettes (folder)
> processing (folder)
> I tried copying the python folder from .qgis to .qgis2 and the plugins
> show up when you check the list, but they are all red , with a comment
> about missing metadata. Any ideas?
> Behind a firewall at work so can't go the normal route for plugins.
> Cheers
> Lester
> On 10 November 2014 09:52, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Hey Lester,
> Any QGIS 2.X version goes into .qgis2 folder with the same setup.
> - Nathan
> On Mon Nov 10 2014 at 7:35:22 PM Lester Anderson <arctica1963 at gmail.com>
> wrote:
> Hello,
> If I need to manually install plugins in QGIS 2.6, where do they go? I
> have the 64-bit version installed.
> For 1.8 I had to put them in C:\Users\lma\.qgis\python\plugins (32-bit) -
> QGIS 2.6 does not read this so the installed plugins list is just the
> default.
> Cheers
> Lester
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141110/5343ce65/attachment.html>
