[Qgis-user] Qgis 2.6 Brighton on Mac Osx 10.10 Yosemite
William Kyngesburye
woklist at kyngchaos.com
Mon Nov 10 20:30:09 PST 2014
In a Terminal window type:
/Library/Frameworks/GDAL.framework/Programs/gdalinfo --formats
and press return (if you follow the GDAL Readme suggestion to change your PATH, you can leave off the /Library...Programs/ part and type just gdalinfo).
ECW should be near the top of the list. If there is a problem, you should see something about that before the format list.
On Nov 10, 2014, at 10:17 PM, Geoff Dickson <dickovich at hotmail.com> wrote:
> Hi and thanks for the prompt reply
> I did that and i get a red error bar - INVALID DATA SOURCE: [quotes map location on laptop and map name.ecw] is not a valid or recognisable data source...
> Seems like my ecw plugin or whatever is not working - is there a way i can generate a file to show you that can give some sense as to what I have done - or not done ?
> Geoff
>> On 11 Nov 2014, at 12:03 pm, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> Try dragging the ECW file from your desktop onto the QGIS window.
>> On Nov 10, 2014, at 9:11 PM, Geoff Dickson <dickovich at hotmail.com> wrote:
>>> Hi list
>>> Complete NEWBIE here, so apologies.
>>> I am trying to install QGIS to allow me to view / convert ecw mapping files.
>>> I have downloaded the latest 2.6 version for mac - I am using OSX 10.10 Yosemite.
>>> I have downloaded the GDAL 1.11 Complete framework files and followed the instructions to install the other dependancies. I have downloaded the ECW plugin1.11.0-1 and ERDAS ECW/JPEG2000 SDK 5.1 and followed install instructions to place certain files throughout my directory structure.
>>> QGIS runs fine, however, when I go to open the ECW map - it is grayed out - indicating to me I cant open it.
>>> Something is broken, or incompatible given I am using Yosemite ?
>>> Can someone help ? Is there a command line method to check my install ? I thought I followed all the instructions but it isn't working and I have an urgent file I need to convert..
>>> Help !!
>>> Geoff
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
