[Qgis-user] Qgis 2.6 Brighton on Mac Osx 10.10 Yosemite
Carlo A. Bertelli (Charta s.r.l.)
carlo.bertelli at gmail.com
Mon Nov 10 23:15:51 PST 2014
Hello Geoff,
the first thing to check is having the right tools in place, this also
helps you to get your ECW file converted.
By the command line, try using GDAL.
/Library/Frameworks/GDAL.framework/Versions/Current/Programs/gdal_translate
WhatYouGet.ECW WhatYouWant.TIF
You may want to refine your conversion with the provided options (you will
find part of them in QGIS menus). Just get some help by issuing:
--help-general
(or --long-usage).
If I remember well, the installer does something to put the current version
of the tools more easily available by symlinking them in your
/usr/local/bin, so you may try omitting this long path an just typing
gdal_translate
It should work. If you don't get your file properly translated, double
check your installation.
c
Date: Tue, 11 Nov 2014 11:11:01 +0800
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Qgis 2.6 Brighton on Mac Osx 10.10 Yosemite
> Message-ID: <BLU437-SMTP358AE4FC02FC15FF4D0C4EB1810 at phx.gbl>
> Content-Type: text/plain; charset="us-ascii"
> Hi list
> Complete NEWBIE here, so apologies.
> I am trying to install QGIS to allow me to view / convert ecw mapping
> files.
> I have downloaded the latest 2.6 version for mac - I am using OSX 10.10
> Yosemite.
> I have downloaded the GDAL 1.11 Complete framework files and followed the
> instructions to install the other dependancies. I have downloaded the ECW
> plugin1.11.0-1 and ERDAS ECW/JPEG2000 SDK 5.1 and followed install
> instructions to place certain files throughout my directory structure.
> QGIS runs fine, however, when I go to open the ECW map - it is grayed out
> - indicating to me I cant open it.
> Something is broken, or incompatible given I am using Yosemite ?
> Can someone help ? Is there a command line method to check my install ? I
> thought I followed all the instructions but it isn't working and I have an
> urgent file I need to convert..
> Help !!
> Geoff
Carlo A. Bertelli
Charta servizi e sistemi per il territorio e la storia ambientale srl
Dipendenze del palazzo Doria,
vc. alla Chiesa della Maddalena 9/2 16124 Genova (Italy)
tel./fax +39(0)10 2475439 +39 0108566195 gsm:+39 393 1590711
e-mail: bertelli at chartasrl.eu http://www.chartasrl.eu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141111/7f262e6f/attachment.html>
