[Qgis-user] Qgis 2.6 Brighton on Mac Osx 10.10 Yosemite
    William Kyngesburye
    woklist at kyngchaos.com
    Tue Nov 11 06:48:35 PST 2014
Strange.  If it works now in QGIS, I guess that's good.  You'll have to look at the GDAL documentation (or the format list) to see if it allows writing for the various formats.
I wonder if you have GDAL_SKIP set in your ~/.bash_profile?  This will ignore listed drivers in the Terminal but not in QGIS.
On Nov 11, 2014, at 2:20 AM, Geoff Dickson <dickovich at hotmail.com> wrote:
> William
> I have uninstalled and reinstalled the GDAL package
> I have reinstalled the ECW plugin and the ERDAS ECW Jpeg2000 file as well
> Output of gdalinfo --formats is below: still now sign of ECW
> However, when I drag the ECW file into the GUI of QGIS - the map opens now - so I take that as a positive !!
> Can I use QGIS to convert to .map, .rmap or .vmap ???
> Geoff
> $ ./gdalinfo --formats
> Supported Formats:
>   VRT (rw+v): Virtual Raster
>   GTiff (rw+vs): GeoTIFF
>   NITF (rw+vs): National Imagery Transmission Format
>   RPFTOC (rovs): Raster Product Format TOC format
>   ECRGTOC (rovs): ECRG TOC format
>   HFA (rw+v): Erdas Imagine Images (.img)
>   SAR_CEOS (rov): CEOS SAR Image
>   CEOS (rov): CEOS Image
>   JAXAPALSAR (rov): JAXA PALSAR Product Reader (Level 1.1/1.5)
>   GFF (rov): Ground-based SAR Applications Testbed File Format (.gff)
>   ELAS (rw+v): ELAS
>   AIG (rov): Arc/Info Binary Grid
>   AAIGrid (rwv): Arc/Info ASCII Grid
>   GRASSASCIIGrid (rov): GRASS ASCII Grid
>   SDTS (rov): SDTS Raster
>   OGDI (ros): OGDI Bridge
>   DTED (rwv): DTED Elevation Raster
>   PNG (rwv): Portable Network Graphics
>   GTA (rwv): Generic Tagged Arrays (.gta)
>   JPEG (rwv): JPEG JFIF
>   MEM (rw+): In Memory Raster
>   JDEM (rov): Japanese DEM (.mem)
>   GIF (rwv): Graphics Interchange Format (.gif)
>   BIGGIF (rov): Graphics Interchange Format (.gif)
>   ESAT (rov): Envisat Image Format
>   FITS (rw+): Flexible Image Transport System
>   BSB (rov): Maptech BSB Nautical Charts
>   XPM (rwv): X11 PixMap Format
>   BMP (rw+v): MS Windows Device Independent Bitmap
>   DIMAP (rov): SPOT DIMAP
>   AirSAR (ro): AirSAR Polarimetric Image
>   RS2 (ros): RadarSat 2 XML Product
>   PCIDSK (rw+v): PCIDSK Database File
>   PCRaster (rw): PCRaster Raster File
>   ILWIS (rw+v): ILWIS Raster Map
>   SGI (rw+): SGI Image File Format 1.0
>   SRTMHGT (rwv): SRTMHGT File Format
>   Leveller (rw+): Leveller heightfield
>   Terragen (rw+): Terragen heightfield
>   GMT (rw): GMT NetCDF Grid Format
>   netCDF (rw+s): Network Common Data Format
>   HDF4 (ros): Hierarchical Data Format Release 4
>   HDF4Image (rw+): HDF4 Dataset
>   ISIS3 (rov): USGS Astrogeology ISIS cube (Version 3)
>   ISIS2 (rw+v): USGS Astrogeology ISIS cube (Version 2)
>   PDS (rov): NASA Planetary Data System
>   TIL (rov): EarthWatch .TIL
>   ERS (rw+v): ERMapper .ers Labelled
>   JP2OpenJPEG (rwv): JPEG-2000 driver based on OpenJPEG library
>   JPEG2000 (rwv): JPEG-2000 part 1 (ISO/IEC 15444-1)
>   L1B (rov): NOAA Polar Orbiter Level 1b Data Set
>   FIT (rwv): FIT Image
>   GRIB (rov): GRIdded Binary (.grb)
>   RMF (rw+v): Raster Matrix Format
>   WCS (rovs): OGC Web Coverage Service
>   WMS (rwvs): OGC Web Map Service
>   MSGN (ro): EUMETSAT Archive native (.nat)
>   RST (rw+v): Idrisi Raster A.1
>   INGR (rw+v): Intergraph Raster
>   GSAG (rwv): Golden Software ASCII Grid (.grd)
>   GSBG (rw+v): Golden Software Binary Grid (.grd)
>   GS7BG (rw+v): Golden Software 7 Binary Grid (.grd)
>   COSAR (ro): COSAR Annotated Binary Matrix (TerraSAR-X)
>   TSX (rov): TerraSAR-X Product
>   COASP (ro): DRDC COASP SAR Processor Raster
>   R (rwv): R Object Data Store
>   MAP (rov): OziExplorer .MAP
>   PNM (rw+v): Portable Pixmap Format (netpbm)
>   DOQ1 (rov): USGS DOQ (Old Style)
>   DOQ2 (rov): USGS DOQ (New Style)
>   ENVI (rw+v): ENVI .hdr Labelled
>   EHdr (rw+v): ESRI .hdr Labelled
>   GenBin (rov): Generic Binary (.hdr Labelled)
>   PAux (rw+): PCI .aux Labelled
>   MFF (rw+): Vexcel MFF Raster
>   MFF2 (rw+): Vexcel MFF2 (HKV) Raster
>   FujiBAS (ro): Fuji BAS Scanner Image
>   GSC (rov): GSC Geogrid
>   FAST (rov): EOSAT FAST Format
>   BT (rw+v): VTP .bt (Binary Terrain) 1.3 Format
>   LAN (rw+v): Erdas .LAN/.GIS
>   CPG (ro): Convair PolGASP
>   IDA (rw+): Image Data and Analysis
>   NDF (rov): NLAPS Data Format
>   EIR (rov): Erdas Imagine Raw
>   DIPEx (rov): DIPEx
>   LCP (rov): FARSITE v.4 Landscape File (.lcp)
>   GTX (rw+v): NOAA Vertical Datum .GTX
>   LOSLAS (rov): NADCON .los/.las Datum Grid Shift
>   NTv2 (rw+vs): NTv2 Datum Grid Shift
>   CTable2 (rw+v): CTable2 Datum Grid Shift
>   ACE2 (rov): ACE2
>   SNODAS (rov): Snow Data Assimilation System
>   ARG (rwv): Azavea Raster Grid format
>   RIK (ro): Swedish Grid RIK (.rik)
>   USGSDEM (rwv): USGS Optional ASCII DEM (and CDED)
>   GXF (ro): GeoSoft Grid Exchange Format
>   DODS (ro): DAP 3.x servers
>   HTTP (ro): HTTP Fetching Wrapper
>   BAG (ro): Bathymetry Attributed Grid
>   HDF5 (ros): Hierarchical Data Format Release 5
>   HDF5Image (ro): HDF5 Dataset
>   NWT_GRD (rov): Northwood Numeric Grid Format .grd/.tab
>   NWT_GRC (rov): Northwood Classified Grid Format .grc/.tab
>   ADRG (rw+vs): ARC Digitized Raster Graphics
>   SRP (rov): Standard Raster Product (ASRP/USRP)
>   BLX (rw): Magellan topo (.blx)
>   Rasterlite (rws): Rasterlite
>   PostGISRaster (rws): PostGIS Raster driver
>   SAGA (rw+v): SAGA GIS Binary Grid (.sdat)
>   KMLSUPEROVERLAY (rwv): Kml Super Overlay
>   XYZ (rwv): ASCII Gridded XYZ
>   HF2 (rwv): HF2/HFZ heightfield raster
>   PDF (rws): Geospatial PDF
>   OZI (rov): OziExplorer Image File
>   CTG (rov): USGS LULC Composite Theme Grid
>   E00GRID (rov): Arc/Info Export E00 GRID
>   WEBP (rwv): WEBP
>   ZMap (rwv): ZMap Plus Grid
>   NGSGEOID (rov): NOAA NGS Geoid Height Grids
>   MBTiles (rov): MBTiles
>   IRIS (rov): IRIS data (.PPI, .CAPPi etc)
>> Begin forwarded message:
>> From: Geoff Dickson <dickovich at hotmail.com>
>> Date: 11 November 2014 3:41:45 pm AWST
>> To: qgis-user at lists.osgeo.org
>> Subject: Re: [Qgis-user] Qgis 2.6 Brighton on Mac Osx 10.10 Yosemite
>> Carlo
>> Ok thankyou.  I have navigated to the first folder location and executed gdal_translate --help-general
>> Output-
>> $ ./gdal_translate
>> Usage: gdal_translate [--help-general] [--long-usage]
>>        [-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
>>              CInt16/CInt32/CFloat32/CFloat64}] [-strict]
>>        [-of format] [-b band] [-mask band] [-expand {gray|rgb|rgba}]
>>        [-outsize xsize[%] ysize[%]]
>>        [-unscale] [-scale [src_min src_max [dst_min dst_max]]]
>>        [-srcwin xoff yoff xsize ysize] [-projwin ulx uly lrx lry] [-epo] [-eco]
>>        [-a_srs srs_def] [-a_ullr ulx uly lrx lry] [-a_nodata value]
>>        [-gcp pixel line easting northing [elevation]]*
>>        [-mo "META-TAG=VALUE"]* [-q] [-sds]
>>        [-co "NAME=VALUE"]* [-stats]
>>        src_dataset dst_dataset
>> I then executed GDAL trying to get a file translated -
>> MYNAME$ ./gdal_translate /users/MYNAME/Desktop/testfile.ecw testoutput.TIF
>> ERROR 4: `/users/MYNAME/Desktop/testfile.ecw' not recognised as a supported file format.
>> GDALOpen failed - 4
>> `/users/dickovich/Desktop/testfile.ecw' not recognised as a supported file format.
>> It would seem that it still does not like the ECW file format - but GDAL appears to be working.
>> How do I fix the ECW element of my install ?
>> Geoff
>>> On 11 Nov 2014, at 3:15 pm, Carlo A. Bertelli (Charta s.r.l.) wrote:
>>> Hello Geoff,
>>> the first thing to check is having the right tools in place, this also helps you to get your ECW file converted.
>>> By the command line, try using GDAL.
>>> /Library/Frameworks/GDAL.framework/Versions/Current/Programs/gdal_translate WhatYouGet.ECW WhatYouWant.TIF
>>> You may want to refine your conversion with the provided options (you will find part of them in QGIS menus). Just get some help by issuing:
>>> /Library/Frameworks/GDAL.framework/Versions/Current/Programs/gdal_translate --help-general
>>> (or --long-usage).
>>> If I remember well, the installer does something to put the current version of the tools more easily available by symlinking them in your /usr/local/bin, so you may try omitting this long path an just typing
>>> gdal_translate
>>> It should work. If you don't get your file properly translated, double check your installation.
>>> c
>>> Date: Tue, 11 Nov 2014 11:11:01 +0800
>>> From: Geoff
>>> Subject: [Qgis-user] Qgis 2.6 Brighton on Mac Osx 10.10 Yosemite
>>> Message-ID: <BLU437-SMTP358AE4FC02FC15FF4D0C4EB1810 at phx.gbl>
>>> Content-Type: text/plain; charset="us-ascii"
>>> Hi list
>>> Complete NEWBIE here, so apologies.
>>> I am trying to install QGIS to allow me to view / convert ecw mapping files.
>>> I have downloaded the latest 2.6 version for mac - I am using OSX 10.10 Yosemite.
>>> I have downloaded the GDAL 1.11 Complete framework files and followed the instructions to install the other dependancies.  I have downloaded the ECW plugin1.11.0-1 and ERDAS ECW/JPEG2000 SDK 5.1 and followed install instructions to place certain files throughout my directory structure.
>>> QGIS runs fine, however, when I go to open the ECW map - it is grayed out - indicating to me I cant open it.
>>> Something is broken, or incompatible given I am using Yosemite ?
>>> Can someone help ? Is there a command line method to check my install ? I thought I followed all the instructions but it isn't working and I have an urgent file I need to convert..
>>> Help !!
>>> Geoff
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
