[Qgis-user] Paths in Processing Options not updated after upgrade to 2.6
Victor Olaya
volayaf at gmail.com
Wed Nov 12 11:41:26 PST 2014
Once the paths are set, a new install of Processing wont change them.
PAths are set only the first time, in case they were not set before.
Maybe we should implement a mechanism for that, assuming the install
path will change between QGIS versions, having a separate set of
options for each Processing version
Thanks for reporting
2014-11-10 19:33 GMT+01:00 Carl <calbury at fs.fed.us>:
> Hello all,
> I'm using Win7, QGIS 2.6
> I just upgraded to 2.6 from 2.4 and I found that the paths in Processing
> Options were still pointing to my old install location (C:\Program
> Files\QGISCH~1\apps\grass\grass-6.4.3) in stead of the current location
> (C:\Program Files\QGISBR~1\apps\grass\grass-6.4.3).
> I tried deleting my .qgis folder and reinstalling, but that didn't help. I
> reset the paths manually in Processing Options and that did the trick, but I
> was wondering if there was a way to avoid going through that process.
> Thanks,
> Carl
> <http://osgeo-org.1560.x6.nabble.com/file/n5172282/processing_optioins.jpg>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Paths-in-Processing-Options-not-updated-after-upgrade-to-2-6-tp5172282.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
