[Qgis-user] Paths in Processing Options not updated after upgrade to 2.6
Jürgen E. Fischer jef at norbit.de
Thu Nov 13 09:08:20 PST 2014
Hi Victor,
On Wed, 12. Nov 2014 at 20:41:26 +0100, Victor Olaya wrote:
> Once the paths are set, a new install of Processing wont change them.
> PAths are set only the first time, in case they were not set before.
> Maybe we should implement a mechanism for that, assuming the install
> path will change  between QGIS versions, having a separate set of
> options for each Processing version
Only if GRASS (or other third party things processing is using) comes with
QGIS.  Common on Windows and OSX, but not on Linux.
2014-11-10 19:33 GMT+01:00 Carl <calbury at fs.fed.us>:
> I tried deleting my .qgis folder and reinstalling, but that didn't help. I
> reset the paths manually in Processing Options and that did the trick, but I
> was wondering if there was a way to avoid going through that process.
> Thanks,
> Carl
On Windows the settings are saved in the registry
(HKEY_CURRENT_USER\Software\QGIS\QGIS2) and on Linux (also OSX?) in the user's
home directory (~/.config/QGIS/QGIS2.conf).
IOW removing ~/.qgis won't reset the settings.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/7197e687/attachment.sig>
