[Qgis-user] Stacking Landsat Bands
Eric Goddard
egoddard1010 at gmail.com
Thu Nov 13 07:12:40 PST 2014
Hi Jonathan, Did you try the GDAL merge tool (Raster -> Miscellaneous
-> Merge)? If you check the layer stack box it will create a multiband
image with any number of input files.
Eric
On Thu, Nov 13, 2014 at 8:31 AM, Carl <calbury at fs.fed.us> wrote:
> Jonathan
> I'm not familiar with the Orfeo tool but I use the SAGA Rgb Composite tool
> under SAGA\Grid-Visualization\ to stack Landsat scenes. It limits you to
> three bands which is a bummer, but works well. The tool output is rescaled
> to 8-bit, so you shouldn't use the stacked imagery for change analysis
> later, but it’s great for visualization.
> The GRASS Raster tool r.composite will also stack, but the SAGA tool seems
> to handle Landsat 7 SLC-off data gaps better.
> I’m new to QGIS, so some of the above might be wrong...
> Carl
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Stacking-Landsat-Bands-tp5172804p5172838.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
