[Qgis-user] Stacking Landsat Bands
Grant Boxer
boxerg at iinet.net.au
Thu Nov 13 16:26:44 PST 2014
Hi All,
As mentioned previously in this post (I think) there is a free program that
combines Landsat 8 bands and pansharpens them as well. The program creates a
GeoTiff file which can be read by QGIS. See this link
"http://www.geosage.com/highview/features_landsat8.html". All you need to do
is download the Landsat 8 data from the USGS and unzip it.
Regards Grant
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of
qgis-user-request at lists.osgeo.org
Sent: Friday, 14 November 2014 4:01 AM
To: qgis-user at lists.osgeo.org
Subject: Qgis-user Digest, Vol 105, Issue 33
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: Raster postGIS problema visualizar en QGIS (Mike Treglia)
2. Re: Stacking Landsat Bands (Carl)
3. Re: Stacking Landsat Bands (Eric Goddard)
4. Re: Stacking Landsat Bands (Andreas Neumann)
5. Re: Drawing over lapping polygons from postgis vector data
table. (Andre Joost)
6. Duplicating a vector layer (Adrian Beasley)
7. Re: Stacking Landsat Bands (Carl)
8. Re: Paths in Processing Options not updated after upgrade to
2.6 (J?rgen E. Fischer)
9. Re: Duplicating a vector layer (Randal Hale)
10. Re: Raster postGIS problema visualizar en QGIS
(Juan Miguel Requena)
Message: 1
Date: Thu, 13 Nov 2014 07:54:54 -0600
To: Juan Miguel Requena <juanmimullor at gmail.com>
Cc: QGIS User <qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Raster postGIS problema visualizar en QGIS
Message-ID: <342B0C8E-8E90-418C-B52C-ECFE7E818533 at gmail.com>
Content-Type: text/plain; charset="utf-8"
Is it a large raster? I don't have experience with remote postgis data, but
I know that if I'm dealing with very large postgis rasters locally, it takes
some time to render.
Hope that helps... I don't have a ton of experience with postgis, so I'm not
sure what else could be going on.
> On Nov 13, 2014, at 7:45 AM, Juan Miguel Requena <juanmimullor at gmail.com>
wrote:
> Hello, some information more, I can visualize shapes from the same data
base.
> Thank you.
> Juanmi
> 2014-11-13 14:42 GMT+01:00 Juan Miguel Requena <juanmimullor at gmail.com>:
>> Hello again, now I have a new problem. I connect into the data base from
other pc without problems (via DB Manager plugin) but when I want to
visualize the raster I can not. However, I can see the info and the table of
the file but not the preliminar view.
>> Any idea?? thank in advance.
>> Juanmi.
>> 2014-11-13 10:46 GMT+01:00 Juan Miguel Requena <juanmimullor at gmail.com>:
>>> Hello Michael, thank you very much for your reply. My problem has been
solved. Indeed, I was trying to import the postGIS raster from the wrong
way, i.e., 'Add PostGIS layer', and when I load it from DB Manager plugin
there is no problem, it was very easy but it was my first time. Thank you
again.
>>> Best regards.
>>> Juanmi.
>>> 2014-11-13 4:35 GMT+01:00 Michael Treglia <mtreglia at gmail.com>:
>>>> Hi Juan,
>>>> To display a PostGIS Raster in QGIS, I think you need to use the
Database Manager plugin ("DB Manager"). If you have it installed/activated,
you would access it from the "Database" tab in the menu bar at top. (I'm
on QGIS 2.6 and 2.4, but I'd imagine its the same for 2.0).
>>>> Is that what you're using to open the PostGIS Raster? Or were you
trying to just use the normal "Add PostGIS layer" method?
>>>> If that's not it, try to give more details of the steps youre taking to
access the PostGIS layer in QGIS.
>>>> Hope that helps,
>>>> Mike
>>>>> On Wed, Nov 12, 2014 at 3:45 PM, Juan Miguel Requena
<juanmimullor at gmail.com> wrote:
>>>>> Hello Alexandre, sorry.
>>>>> I have used the postGIS command 'raster2pgsql' to import a geotiff
file into a postgres data base.The process was successfully finished. Both
columns 'rid' and 'rast' were successfully created but when I connect QGIS
2.0 to the data base and load the table, the software is unable to recognize
the data type and the geometry type, so that I can not visualize the file
and the attribute table has not the rast column.
>>>>> Thank you in advance for your help
>>>>> Juanmi
>>>>> El 12 de noviembre de 2014, 20:51, Alexandre Neto
<senhor.neto at gmail.com> escribi?:
>>>>>> Hello Juan, can I ask you to write your question in English?
>>>>>> Thanks,
>>>>>> Alexandre Neto
>>>>>> Em 12/11/2014 16:25, "Juan Miguel Requena" <juanmimullor at gmail.com>
escreveu:
>>>>>>> Hola, estoy utilizando el comando raster2pgsql de postGIS para
importar un archivo geotif a una base de datos (postgresql). Todo el proceso
lo ejecuta correctamente. Crea los campos 'rid' y 'rast' bien. Pero al
conectarme a la base de datos con QGIS, la tabla postgres correspondiente
viene como 'Tipo de dato' : Nada y 'Tipo espacial' : Ninguna geometr?a.
Cuando a?ado el archivo y visualizo la tabla de atributos solo existe el
campo 'rid' pero no el 'rast'.
>>>>>>> Alguien puede echarme un mano, muchas gracias por adelantado.
>>>>>>> Juanmi.
>>>>>>> _______________________________________________
>>>>>>> Qgis-user at lists.osgeo.org
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/1aaa9db7/at
tachment-0001.html>
Message: 2
Date: Thu, 13 Nov 2014 06:31:30 -0800 (PST)
Subject: Re: [Qgis-user] Stacking Landsat Bands
Message-ID: <1415889090030-5172838.post at n6.nabble.com>
Content-Type: text/plain; charset=UTF-8
Jonathan
I'm not familiar with the Orfeo tool but I use the SAGA Rgb Composite tool
under SAGA\Grid-Visualization\ to stack Landsat scenes. It limits you to
three bands which is a bummer, but works well. The tool output is rescaled
to 8-bit, so you shouldn't use the stacked imagery for change analysis
later, but it?s great for visualization.
The GRASS Raster tool r.composite will also stack, but the SAGA tool seems
to handle Landsat 7 SLC-off data gaps better.
I?m new to QGIS, so some of the above might be wrong...
Carl
View this message in context:
http://osgeo-org.1560.x6.nabble.com/Stacking-Landsat-Bands-tp5172804p5172838
.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Message: 3
Date: Thu, 13 Nov 2014 09:12:40 -0600
To: Carl <calbury at fs.fed.us>
Cc: qgis-user <qgis-user at lists.osgeo.org>
Message-ID:
<CAMM2+YrH6Jebr41cNrPDQobh4wjBycVO4-+kdqus2SpTspaXew at mail.gmail.com>
Hi Jonathan, Did you try the GDAL merge tool (Raster -> Miscellaneous
-> Merge)? If you check the layer stack box it will create a multiband
image with any number of input files.
Eric
On Thu, Nov 13, 2014 at 8:31 AM, Carl <calbury at fs.fed.us> wrote:
> Jonathan
> tool under SAGA\Grid-Visualization\ to stack Landsat scenes. It limits
> you to three bands which is a bummer, but works well. The tool output
> is rescaled to 8-bit, so you shouldn't use the stacked imagery for
> change analysis later, but it?s great for visualization.
> seems to handle Landsat 7 SLC-off data gaps better.
> Carl
> 172838.html Sent from the Quantum GIS - User mailing list archive at
> Nabble.com.
Message: 4
Date: Thu, 13 Nov 2014 16:25:17 +0100
Message-ID: <b838791e5a20a9fee205de3508a6f357 at carto.net>
Content-Type: text/plain; charset=UTF-8; format=flowed
If it is just for display you can display the landsat image in QGIS right
away. You can freely assign selected bands to rgb channels in the "Style"
tab of QGIS. So no need to recalculate images ...
Andreas
Am 2014-11-13 16:12, schrieb Eric Goddard:
> Eric
>> Jonathan
>> limits you to three bands which is a bummer, but works well. The tool
>> output is rescaled to 8-bit, so you shouldn't use the stacked imagery
>> for change analysis later, but it?s great for visualization.
>> Carl
>> 5172838.html Sent from the Quantum GIS - User mailing list archive at
>> Nabble.com.
Message: 5
Date: Thu, 13 Nov 2014 17:36:14 +0100
Subject: Re: [Qgis-user] Drawing over lapping polygons from postgis
vector data table.
Message-ID: <m42mr4$e7g$1 at ger.gmane.org>
Content-Type: text/plain; charset=windows-1252; format=flowed
Am 13.11.2014 um 10:34 schrieb Dave Potts:
> Hi
> I am trying to display the results of a spatial analysis, the return
> form is a set of polygons of increasing size. All located on top of
> each other. I want to draw it, so it looks like a target, but all
> that happens is that the largest polygon is drawn last which blocks
> out all of the others. Is there an easy way of display the result?
> I can not see any way of using an outside function so that the largest
> polygon would be drawn firsts with the next polygon drawn on top of it.
> Since its an import from a postgis table every does have an unique id.
In Layer Properties, Style tab you can use a categorized or graduated style
based on the unique id, or some other field of the attribute table.
Then click on the "Advanced" button beneath the symbol table, and select
"Symbol levels". If you check "Enable symbol levels", you can predefine in
which order your symbols should be rendered.
You can even set all colours equal or a fill style "No Brush" if you only
want to see the contours.
HTH,
Andr? Joost
Message: 6
Date: Thu, 13 Nov 2014 16:38:56 +0000
From: Adrian Beasley <adrian.beasley at outlook.com>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Duplicating a vector layer
Message-ID: <BLU174-W230F4F3D46C39A8F9D8D6E868F0 at phx.gbl>
Content-Type: text/plain; charset="iso-8859-1"
I am new to QGIS, still very much learning how to use it.
What I wish to do is generate a number of similar vector layers, to be able
to generate slightly different maps from them. The obvious way would seem to
be to duplicate an existing layer, renaming the new copy, and editing it.
But this seems not to produce a new, distinct layer, as making changes to
either the original or the new layer causes the same changes in both.
I can find no mention of this facility in the user guide nor in the training
documentation. Can anyone help?
Thanks in anticipation.
Adrian Beasley
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/aea8a7ca/at
tachment-0001.html>
Message: 7
Date: Thu, 13 Nov 2014 09:07:45 -0800 (PST)
Message-ID: <1415898465785-5172874.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
Thanks Eric,
That is a better tool than what I was using (I like to stack all 7 bands).
Carl
http://osgeo-org.1560.x6.nabble.com/Stacking-Landsat-Bands-tp5172804p5172874
.html
Message: 8
Date: Thu, 13 Nov 2014 18:08:20 +0100
Subject: Re: [Qgis-user] Paths in Processing Options not updated
after
upgrade to 2.6
Message-ID: <20141113170820.GA24490 at norbit.de>
Hi Victor,
On Wed, 12. Nov 2014 at 20:41:26 +0100, Victor Olaya wrote:
> Once the paths are set, a new install of Processing wont change them.
> PAths are set only the first time, in case they were not set before.
> Maybe we should implement a mechanism for that, assuming the install
> path will change between QGIS versions, having a separate set of
> options for each Processing version
Only if GRASS (or other third party things processing is using) comes with
QGIS. Common on Windows and OSX, but not on Linux.
2014-11-10 19:33 GMT+01:00 Carl <calbury at fs.fed.us>:
> I tried deleting my .qgis folder and reinstalling, but that didn't
> help. I reset the paths manually in Processing Options and that did
> the trick, but I was wondering if there was a way to avoid going through
that process.
> Thanks,
> Carl
On Windows the settings are saved in the registry
(HKEY_CURRENT_USER\Software\QGIS\QGIS2) and on Linux (also OSX?) in the
user's home directory (~/.config/QGIS/QGIS2.conf).
IOW removing ~/.qgis won't reset the settings.
J?rgen
J?rgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstra?e 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: Digital signature
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/7197e687/at
tachment-0001.pgp>
Message: 9
Date: Thu, 13 Nov 2014 12:11:03 -0500
From: Randal Hale <rjhale at northrivergeographic.com>
To: Adrian Beasley <adrian.beasley at outlook.com>,
Subject: Re: [Qgis-user] Duplicating a vector layer
Message-ID: <5464E627.7020209 at northrivergeographic.com>
Content-Type: text/plain; charset="windows-1252"; Format="flowed"
Probably the easiest thing for you to do is to right click on the layer and
go to "save as". That will save/export your current layer as a new one and
allow the edits you want to make. All you would need to do is add it to you
qgis session.
Hope that helps,
Randy
> able to generate slightly different maps from them. The obvious way
> would seem to be to duplicate an existing layer, renaming the new
> copy, and editing it. But this seems not to produce a new, distinct
> layer, as making changes to either the original or the new layer
> training documentation. Can anyone help?
> Adrian Beasley
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale http://about.me/rjhale
http://www.northrivergeographic.com/spatial-connect
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/85f3d0b3/at
tachment-0001.html>
Message: 10
Date: Thu, 13 Nov 2014 18:43:43 +0100
From: Juan Miguel Requena <juanmimullor at gmail.com>
To: Mike Treglia <mtreglia at gmail.com>
Message-ID:
<CAHDzixAeXkH7YRv+dKid=XV7q1z+CK1sJy1_2NM8E5GCFFUpzw at mail.gmail.com>
Hi Mike, I agree, I think that it is a problem related to the file size
because QGIS does not report any failure, just takes too. I am going to try
with another smaller file.
Thank you.
Juanmi.
2014-11-13 14:54 GMT+01:00 Mike Treglia <mtreglia at gmail.com>:
> data, but I know that if I'm dealing with very large postgis rasters
> locally, it takes some time to render.
> I'm not sure what else could be going on.
> data base.
> Thank you.
> Juanmi
>> from other pc without problems (via DB Manager plugin) but when I
>> want to visualize the raster I can not. However, I can see the info
>> and the table of the file but not the preliminar view.
>> Juanmi.
>>> been solved. Indeed, I was trying to import the postGIS raster from
>>> the wrong way, i.e., 'Add PostGIS layer', and when I load it from DB
>>> Manager plugin there is no problem, it was very easy but it was my
>>> first time. Thank you again.
>>> Best regards.
>>> Juanmi.
>>>> Hi Juan,
(I'm
>>>> taking to access the PostGIS layer in QGIS.
>>>> Hope that helps,
>>>> Mike
>>>> On Wed, Nov 12, 2014 at 3:45 PM, Juan Miguel Requena <
>>>>> finished. Both columns 'rid' and 'rast' were successfully created
>>>>> recognize the data type and the geometry type, so that I can not
>>>>> visualize the file and the attribute table has not the rast column.
>>>>> Juanmi
>>>>> El 12 de noviembre de 2014, 20:51, Alexandre Neto <
>>>>>> Thanks,
>>>>>> Alexandre Neto
>>>>>> escreveu:
>>>>>>> Todo el proceso lo ejecuta correctamente. Crea los campos 'rid'
>>>>>>> y 'rast' bien. Pero al conectarme a la base de datos con QGIS,
>>>>>>> la tabla postgres correspondiente viene como 'Tipo de dato' : Nada y
'Tipo espacial' :
>>>>>>> Ninguna geometr?a. Cuando a?ado el archivo y visualizo la tabla
>>>>>>> de atributos solo existe el campo 'rid' pero no el 'rast'.
>>>>>>> Juanmi.
URL:
<http://lists.osgeo.org/pipermail/qgis-user/attachments/20141113/1c161c8e/at
tachment-0001.html>
End of Qgis-user Digest, Vol 105, Issue 33
