[Qgis-user] Original Shapefile update
Leahy, Thomas A.
tleahy at bechtel.com
Sat Nov 15 23:20:30 PST 2014
Hello,
Does QGIS update the original Shapefile when I make changes in a project?
I have two QGIS projects that are pointed to the same original shapefile so if I make a change or update in one I expected to see the changes in the other project, but I don't
Also if I open a new QGIS project which points to the same shapefile I would expect to see the same fields and data but I don't.
Is there any way (some setting) I can make all the projects which point to the shapefile display the same fields and data.?
All the QGIS projects should update the original shapefile and use it.
Best Regards,
Tom
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141116/0806091d/attachment.html>
