[Qgis-user] Original Shapefile update
Alexandre Neto
senhor.neto at gmail.com
Sun Nov 16 08:35:41 PST 2014
Hello Tom,
Any change made to a shapefile in one project will be updated in other
projects that use the same shapefile.
This happens only after you save your edits. It is limited to the data
itself (features geometries and attributes), it does not apply to any
styles, filters or widgets of the project layer.
Make sure you are really saving the data edits (and not the project), and
that you're really using the same shapefile.
Best regards,
Alexandre Neto
Em 16/11/2014 07:21, "Leahy, Thomas A." <tleahy at bechtel.com> escreveu:
> Hello,
> Does QGIS update the original Shapefile when I make changes in a
> project?
> I have two QGIS projects that are pointed to the same original
> shapefile so if I make a change or update in one I expected to see the
> changes in the other project, but I don’t
> Also if I open a new QGIS project which points to the same shapefile I
> would expect to see the same fields and data but I don’t.
> Is there any way (some setting) I can make all the projects which point to
> the shapefile display the same fields and data.?
> All the QGIS projects should update the original shapefile and use it.
> Best Regards,
> Tom
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141116/e59d6638/attachment.html>
