[Qgis-user] Failure with CadTools and QGIS 2.6
Marcel Stadelmann
marcel.stadelmann at gmx.net
Mon Nov 17 03:11:41 PST 2014
On the new QGIS 2.6 I get a python failure while drawing a orthogonal line with the CadTools plugin. Is this a general problem or is it just on my machine? I use a Mac with OSX 10.8.5 and I get the following python failure:
File "/Users/Marcello/.qgis2/python/plugins/cadtools/tools/orthoelementsonsegmenttool.py", line 77, in ortholineandpoint
cadutils.addGeometryToCadLayer(QgsGeometry.fromPoint(p))
File "/Users/Marcello/.qgis2/python/plugins/cadtools/tools/cadutils.py", line 38, in addGeometryToCadLayer
QgsMapLayerRegistry().instance().addMapLayer(vl, True)
TypeError: qgis._core.QgsMapLayerRegistry cannot be instantiated or sub-classed
Python-Version:
2.7.2 (default, Oct 11 2012, 20:14:37)
[GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]
QGIS-Version:
2.6.0-Brighton Brighton,
Python-Pfad: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing', '/Users/Marcello/.qgis2/python/plugins/GeoCoding', '/Applications/QGIS.app/Contents/MacOS/../Resources/python', u'/Users/Marcello/.qgis2/python', u'/Users/Marcello/.qgis2/python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7', '/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7', '/Library/Python/2.7/site-packages/numpy-override', '/Library/Python/2.7/site-packages/matplotlib-override', '/Library/Frameworks/MapServer.framework/Versions/6.0/Python/2.7', '/Library/Frameworks/GDAL.framework/Versions/1.11/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/distribute-0.6.35-py2.7.egg', '/Library/Python/2.7/site-packages/pip-1.3.1-py2.7.egg', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.7', '/usr/local/lib/wxPython-3.0.0.0/lib/python2.7/site-packages', '/usr/local/lib/wxPython-3.0.0.0/lib/python2.7/site-packages/wx-3.0-osx_cocoa', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload', '/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC', '/Library/Python/2.7/site-packages', '/Library/Python/2.7/site-packages/PIL', '/Library/Python/2.7/site-packages/setuptools-0.6c11-py2.7.egg-info', '/usr/local/lib/wxPython-3.0.0.0/lib/python2.7', '/Users/Marcello/.qgis2/python/plugins/MetaSearch/ext-libs', '/Users/Marcello/.qgis2/python/plugins/mmqgis/forms', '/Applications/QGIS.app/Contents/Resources/python/plugins/fTools/tools', '/Users/Marcello/Documents/Studium/Archaeologie/UFG/Masterarbeit/GIS']
Marcel
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141117/d67aa9a5/attachment.html>
