[Qgis-user] Raster: replace a single value with another value
Andreas Neumann
a.neumann at carto.net
Mon Nov 17 09:02:20 PST 2014
I have a very simple task (at least I thought it is simple), but am not
able to do it properly.
I have a grayscale tiff value where I would like to replace the value of
249 with 255 - all other values should stay as they are.
I tried with gdal "nearblack", but nothing changed - I started a
separate email-thread about that at the gdal list.
Then I tried with the QGIS raster calculator - but it does not support
conditional syntax.
I tried with Processing and GRASS - but it would stop at 8% - the file
is quite big.
Finally I came across SAGA "Reclassify with grid value". The dialogue is
very complicated and hard to understand. After a while it would stop
with an error message telling me that Saga may not be properly
configured - but it says that it is properly installed. Quite confusing
I am trying on Win7 64bit.
If the file wouldn't be so big I would try this task in The Gimp - where
it is very simple to replace one pixel values with another - using
"Select by color" and "fill with a specific color".
Any idea how I could achieve my task with GDAL, QGIS, GRASS or Saga?
Thanks,
Andreas
