[Qgis-user] [Bulk] Print Maps with Open Layers Imagery
Jeff Partain
jbpartain at gmail.com
Mon Nov 17 09:22:34 PST 2014
Check out this thread...
*http://osgeo-org.1560.x6.nabble.com/Printing-td4680601.html
<http://osgeo-org.1560.x6.nabble.com/Printing-td4680601.html>*
*Response from Giovanni Manghi-2
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=user_nodes&user=191865>:*
*"this happens because the layers from the Openlayers Plugin are not *
*available at every scale, but only at certain scale levels (so when
you add such layers all the project is available only at preset scales). In
the composer you then need to manually set the scale of the map object to
be one of those scale levels, otherwise you'll get the described issue." *
*Response from Zirneklitis
<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=user_nodes&user=235580>:*
*1128.497220 *
*2256.994440 4513.988880 9027.977761 18055.955520 36111.911040
72223.822090 144447.644200 288895.288400 577790.576700 1155581.153000
2311162.307000 4622324.614000 9244649.227000 18489298.450000
36978596.910000 73957193.820000 147914387.600000 295828775.300000
591657550.500000*
I rounded the scales to whole numbers and it works great. (I'm not using
2.6 yet)
On Mon, Nov 17, 2014 at 12:15 PM, Frank van Baar <frank at van-baar.com> wrote:
> Hi Guido,
> I have the same issue and I don’t use the composer therefore. If you just
> want to print the map without any additional make up etc. just save it as
> JPEG or PNG from project – save as image. This way you can wait until the
> map and shp file align. Hope that helps you?
> Frank
> *Van:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *Namens *Guido Maregatti
> *Verzonden:* 17 November 2014 17:35
> *Aan:* Qgis
> *Onderwerp:* [Bulk] [Qgis-user] Print Maps with Open Layers Imagery
> Most of the time when I try to print a map using Open Layers Imagery as a
> background layer, Google, Open Street or else, I get a printed map that
> doesn't sync with my shp files. It's a random issue in the matter that
> sometimes it works fine, but most of the time it screws up everything, so
> my hope is that I am doing, unaware, something wrong. Unlike Mike
> problems to print big maps in my case I am trying to print just A4 size.
> Besides frustrations, being unable to print my maps makes completely
> useless for me to use QGIS. I am working with QGIS 2.6 64bit on Windows 7.
> Very appreciated any help to fix this issue.
> Guido
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141117/594d5b6d/attachment.html>
