[Qgis-user] Raster: replace a single value with another value
Michael Treglia
mtreglia at gmail.com
Tue Nov 18 09:48:27 PST 2014
Andreas,
You're running 64bit SAGA, right? (if not sure, click the question mark on
the menu bar, and click "About" - should be towards the top).
I actually like SAGA because I can throw pretty giant files at it. Just to
test out and make sure, I just loaded in a 10GB GeoTIFF with integer
values, and did a single value reclass that took about 3 minutes. You
likely need ample RAM and disk space, but given that you do, it should be
feasible. [Watching the system resources, you can see the respective amount
of memory get taken up as you work with data in SAGA]
The 4GB limit seems like it could be a 32 bit issue. I was using the
latest version of SAGA (2.1.3), 64 bit, downloaded from:
http://sourceforge.net/projects/saga-gis/files/SAGA%20-%202.1/SAGA%202.1.3/
If you're really stuck and need to knock this task out of the way - if you
can get me the data I can do the reclass for you.
hope that helps,
mike
On Tue, Nov 18, 2014 at 10:04 AM, Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi Carlos,
> I reprojected to a different swiss projection system and the expression
> still does not work. I tested various projections, including UTM-32N. Very
> strange ...
> There clearly seems to be a bug in the raster calculator. I will open a
> bug with high priority.
> Thanks for testing and helping!
> Andreas
> Am 2014-11-18 15:36, schrieb Carlos Cerdán:
>> Hi Andreas:
>> It is solved: you have to reproject your TEMP layer. I've tried with
>> UTM-32N zone and raster calculator works fine.
>> Why raster calculator (and SAGA) doesn't work with your original CRS?
>> Well, I don't know, perhaps devs group have the answer.
>> It was a good challenge.
>> Carlos
>> 2014-11-18 4:37 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi Carlos,
>>> Thank you for your help!
>>> I tried with
>>> (TEMP at 1=249)*255 + (TEMP at 1<249)*TEMP at 1 + (TEMP at 1>249)*TEMP at 1
>>> My layer is called "temp". However, the resulting file contains all
>>> 0.
>>> I tried in both QGIS 2.4 and 2.6.
>>> Is there something wrong with the input file? It was generated from
>>> a PDF with ghostscript. Here is the metadata:
>>> GDAL provider
>>> GTiff
>>> GeoTIFF
>>> Datensatzbeschreibung
>>> //gis/gis/mapserverdata/uep/release_2014_11/temp.tif
>>> TIFFTAG_DATETIME=2014:11:17 09:50:08
>>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>>> TIFFTAG_SOFTWARE=GPL Ghostscript 9.10
>>> TIFFTAG_XRESOLUTION=600
>>> TIFFTAG_YRESOLUTION=600
>>> Kanal 1
>>> STATISTICS_MAXIMUM=255
>>> STATISTICS_MEAN=247.18714741724
>>> STATISTICS_MINIMUM=0
>>> STATISTICS_STDDEV=37.198102288306
>>> Dimensionen
>>> X: 71575 Y: 70867 Kanäle: 1
>>> Leerwert
>>> *Leerwert nicht gesetzt*
>>> Datentyp
>>> Byte - Acht Bit vorzeichenlose Ganzzahl
>>> Pyramidenübersichten
>>> Räumliches Bezugssystem des Layers
>>> +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333
>>> +k_0=1 +x_0=600000 +y_0=200000 +ellps=bessel
>>> +towgs84=674.4,15.1,405.3,0,0,0,0 +units=m +no_defs
>>> Layerausdehnung (in urspünglicher Projektion des Layers)
>>> 0.0000000000000000,-70867.0000000000000000 :
>>> 71575.0000000000000000,0.0000000000000000
>>> Kanal
>>> Kanal 1
>>> Kanal Nr
>>> 1
>>> Keine Statistik
>>> Noch keine Statistik gesammelt
>>> Thanks again if you have any idea what may be wrong with my file or
>>> the above listed raster calc statement.
>>> Andreas
>>> Am 2014-11-17 18:38, schrieb Carlos Cerdán:
>>> Hi Andreas:
>>> I think QGIS raster calculator can make this job. Conditional
>>> syntax
>>> is a little bit... different. The sentence that can do it is:
>>> (TIFF=249)*255 + (TIFF<249)*TIFF + (TIFF>249)*TIFF
>>> Where TIFF is your raster layer. The trick is: if the sentence in
>>> parentheses is true, it gets value 1, else zero; so we have to
>>> multiply by 255 to replace the 249 values. Next we have to add the
>>> other values.
>>> Good luck,
>>> Carlos Cerdán
>>> PD. Please let me know if i'm wrong with this suggestion
>>> 2014-11-17 12:02 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>>> Hi,
>>> I have a very simple task (at least I thought it is simple), but am
>>> not able to do it properly.
>>> I have a grayscale tiff value where I would like to replace the
>>> value of 249 with 255 - all other values should stay as they are.
>>> I tried with gdal "nearblack", but nothing changed - I started a
>>> separate email-thread about that at the gdal list.
>>> Then I tried with the QGIS raster calculator - but it does not
>>> support conditional syntax.
>>> I tried with Processing and GRASS - but it would stop at 8% - the
>>> file is quite big.
>>> Finally I came across SAGA "Reclassify with grid value". The
>>> dialogue is very complicated and hard to understand. After a while
>>> it would stop with an error message telling me that Saga may not be
>>> properly configured - but it says that it is properly installed.
>>> Quite confusing ...
>>> I am trying on Win7 64bit.
>>> If the file wouldn't be so big I would try this task in The Gimp -
>>> where it is very simple to replace one pixel values with another -
>>> using "Select by color" and "fill with a specific color".
>>> Any idea how I could achieve my task with GDAL, QGIS, GRASS or
>>> Saga?
>>> Thanks,
>>> Andreas
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user [1] [1]
>>> Links:
>>> [1] http://lists.osgeo.org/mailman/listinfo/qgis-user [1]
>> Links:
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141118/73287d1c/attachment.html>
