[Qgis-user] Raster: replace a single value with another value
Andreas Neumann
a.neumann at carto.net
Tue Nov 18 23:58:48 PST 2014
Hi Michael,
Thank you for reply.
Seems I am running Saga 2.08 64 bit (see
http://webgis.uster.ch/temp/saga_about_tool.png) - it is the one
provided with the OSGeo4W installer and which integrates with QGIS
processing.
Should I try a newer version? Version 2.1? Would that work better with
big files?
Here is the dialogue with my reclassify settings:
http://webgis.uster.ch/temp/saga_reclass_settings.png
and here the error message (not very useful, I know):
http://webgis.uster.ch/temp/saga_about_tool_reclassify_error_message.png
I will probably try to install a newer SAGA version (hopefully I can do
this in parallel with OSGeo4W).
My task is not so super urgent. I just want to try to do all with FOSS
software.
Thanks a lot so far,
Andreas
Am 2014-11-18 18:48, schrieb Michael Treglia:
> Andreas,
> You're running 64bit SAGA, right? (if not sure, click the question
> mark on the menu bar, and click "About" - should be towards the top).
> I actually like SAGA because I can throw pretty giant files at it.
> Just to test out and make sure, I just loaded in a 10GB GeoTIFF with
> integer values, and did a single value reclass that took about 3
> minutes. You likely need ample RAM and disk space, but given that you
> do, it should be feasible. [Watching the system resources, you can see
> the respective amount of memory get taken up as you work with data in
> SAGA]
> The 4GB limit seems like it could be a 32 bit issue. I was using the
> latest version of SAGA (2.1.3), 64 bit, downloaded from:
> http://sourceforge.net/projects/saga-gis/files/SAGA%20-%202.1/SAGA%202.1.3/
> [2]
> If you're really stuck and need to knock this task out of the way - if
> you can get me the data I can do the reclass for you.
> hope that helps,
> mike
> On Tue, Nov 18, 2014 at 10:04 AM, Andreas Neumann
> <a.neumann at carto.net> wrote:
>> Hi Carlos,
>> I reprojected to a different swiss projection system and the
>> expression still does not work. I tested various projections,
>> including UTM-32N. Very strange ...
>> There clearly seems to be a bug in the raster calculator. I will
>> open a bug with high priority.
>> Thanks for testing and helping!
>> Andreas
>> Am 2014-11-18 15:36, schrieb Carlos Cerdán:
>> Hi Andreas:
>> It is solved: you have to reproject your TEMP layer. I've tried
>> with
>> UTM-32N zone and raster calculator works fine.
>> Why raster calculator (and SAGA) doesn't work with your original
>> CRS?
>> Well, I don't know, perhaps devs group have the answer.
>> It was a good challenge.
>> Carlos
>> 2014-11-18 4:37 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi Carlos,
>> Thank you for your help!
>> I tried with
>> (TEMP at 1=249)*255 + (TEMP at 1<249)*TEMP at 1 + (TEMP at 1>249)*TEMP at 1
>> My layer is called "temp". However, the resulting file contains all
>> 0.
>> I tried in both QGIS 2.4 and 2.6.
>> Is there something wrong with the input file? It was generated from
>> a PDF with ghostscript. Here is the metadata:
>> GDAL provider
>> GTiff
>> GeoTIFF
>> Datensatzbeschreibung
>> //gis/gis/mapserverdata/uep/release_2014_11/temp.tif
>> TIFFTAG_DATETIME=2014:11:17 09:50:08
>> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
>> TIFFTAG_SOFTWARE=GPL Ghostscript 9.10
>> TIFFTAG_XRESOLUTION=600
>> TIFFTAG_YRESOLUTION=600
>> Kanal 1
>> STATISTICS_MAXIMUM=255
>> STATISTICS_MEAN=247.18714741724
>> STATISTICS_MINIMUM=0
>> STATISTICS_STDDEV=37.198102288306
>> Dimensionen
>> X: 71575 Y: 70867 Kanäle: 1
>> Leerwert
>> *Leerwert nicht gesetzt*
>> Datentyp
>> Byte - Acht Bit vorzeichenlose Ganzzahl
>> Pyramidenübersichten
>> Räumliches Bezugssystem des Layers
>> +proj=somerc +lat_0=46.95240555555556 +lon_0=7.439583333333333
>> +k_0=1 +x_0=600000 +y_0=200000 +ellps=bessel
>> +towgs84=674.4,15.1,405.3,0,0,0,0 +units=m +no_defs
>> Layerausdehnung (in urspünglicher Projektion des Layers)
>> 0.0000000000000000,-70867.0000000000000000 :
>> 71575.0000000000000000,0.0000000000000000
>> Kanal
>> Kanal 1
>> Kanal Nr
>> 1
>> Keine Statistik
>> Noch keine Statistik gesammelt
>> Thanks again if you have any idea what may be wrong with my file or
>> the above listed raster calc statement.
>> Andreas
>> Am 2014-11-17 18:38, schrieb Carlos Cerdán:
>> Hi Andreas:
>> I think QGIS raster calculator can make this job. Conditional
>> syntax
>> is a little bit... different. The sentence that can do it is:
>> (TIFF=249)*255 + (TIFF<249)*TIFF + (TIFF>249)*TIFF
>> Where TIFF is your raster layer. The trick is: if the sentence in
>> parentheses is true, it gets value 1, else zero; so we have to
>> multiply by 255 to replace the 249 values. Next we have to add the
>> other values.
>> Good luck,
>> Carlos Cerdán
>> PD. Please let me know if i'm wrong with this suggestion
>> 2014-11-17 12:02 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> I have a very simple task (at least I thought it is simple), but am
>> not able to do it properly.
>> I have a grayscale tiff value where I would like to replace the
>> value of 249 with 255 - all other values should stay as they are.
>> I tried with gdal "nearblack", but nothing changed - I started a
>> separate email-thread about that at the gdal list.
>> Then I tried with the QGIS raster calculator - but it does not
>> support conditional syntax.
>> I tried with Processing and GRASS - but it would stop at 8% - the
>> file is quite big.
>> Finally I came across SAGA "Reclassify with grid value". The
>> dialogue is very complicated and hard to understand. After a while
>> it would stop with an error message telling me that Saga may not be
>> properly configured - but it says that it is properly installed.
>> Quite confusing ...
>> I am trying on Win7 64bit.
>> If the file wouldn't be so big I would try this task in The Gimp -
>> where it is very simple to replace one pixel values with another -
>> using "Select by color" and "fill with a specific color".
>> Any idea how I could achieve my task with GDAL, QGIS, GRASS or
>> Saga?
>> Thanks,
>> Andreas
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [1] [1] [1]
>> Links:
>> [1] http://lists.osgeo.org/mailman/listinfo/qgis-user [1] [1]
>> Links:
> Links:
> [2]
