[Qgis-user] QGIS 2.6 installation
Brent Wood pcreso at pcreso.com
Wed Nov 19 23:56:54 PST 2014
Something looks confused here. The first error is from trying to execute a SAGA gis command, not GRASS gis. Looks like GRASS may then be failing to load the file which should have been generated by SAGA. If you can resolve this error, the GRASS one may go away too.
|Could not load model watersheds.model|Error in algorithm name: saga:catchmentareaparallel ALGORITHM
If you are not, you might try running it with the Python console open?
Brent Wood
      From: "PadmaDevi.Subramaniam at cognizant.com" <PadmaDevi.Subramaniam at cognizant.com>
 To: pcreso at pcreso.com
Cc: qgis-user at lists.osgeo.org
 Sent: Thursday, November 20, 2014 8:26 PM
 Subject: RE: [Qgis-user] QGIS 2.6 installation
#yiv1466261196 #yiv1466261196 -- _filtered #yiv1466261196 {font-family:Helvetica;panose-1:2 11 6 4 2 2 2 2 2 4;} _filtered #yiv1466261196 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #yiv1466261196 {font-family:Wingdings;panose-1:5 0 0 0 0 0 0 0 0 0;} _filtered #yiv1466261196 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;} _filtered #yiv1466261196 {font-family:Tahoma;panose-1:2 11 6 4 3 5 4 4 2 4;} _filtered #yiv1466261196 {font-family:Georgia;panose-1:2 4 5 2 5 4 5 2 3 3;}#yiv1466261196 #yiv1466261196 p.yiv1466261196MsoNormal, #yiv1466261196 li.yiv1466261196MsoNormal, #yiv1466261196 div.yiv1466261196MsoNormal {margin:0in;margin-bottom:.0001pt;font-size:12.0pt;}#yiv1466261196 a:link, #yiv1466261196 span.yiv1466261196MsoHyperlink {color:blue;text-decoration:underline;}#yiv1466261196 a:visited, #yiv1466261196 span.yiv1466261196MsoHyperlinkFollowed {color:purple;text-decoration:underline;}#yiv1466261196 p.yiv1466261196MsoAcetate, #yiv1466261196 li.yiv1466261196MsoAcetate, #yiv1466261196 div.yiv1466261196MsoAcetate {margin:0in;margin-bottom:.0001pt;font-size:8.0pt;}#yiv1466261196 span.yiv1466261196link-enhancr-element {}#yiv1466261196 span.yiv1466261196link-enhancr-view-on-domain {}#yiv1466261196 p.yiv1466261196msonormal, #yiv1466261196 li.yiv1466261196msonormal, #yiv1466261196 div.yiv1466261196msonormal {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv1466261196 p.yiv1466261196msochpdefault, #yiv1466261196 li.yiv1466261196msochpdefault, #yiv1466261196 div.yiv1466261196msochpdefault {margin-right:0in;margin-left:0in;font-size:12.0pt;}#yiv1466261196 span.yiv1466261196msohyperlink {}#yiv1466261196 span.yiv1466261196msohyperlinkfollowed {}#yiv1466261196 span.yiv1466261196emailstyle17 {}#yiv1466261196 span.yiv1466261196emailstyle18 {}#yiv1466261196 p.yiv1466261196msonormal1, #yiv1466261196 li.yiv1466261196msonormal1, #yiv1466261196 div.yiv1466261196msonormal1 {margin:0in;margin-bottom:.0001pt;font-size:11.0pt;}#yiv1466261196 span.yiv1466261196msohyperlink1 {color:blue;text-decoration:underline;}#yiv1466261196 span.yiv1466261196msohyperlinkfollowed1 {color:purple;text-decoration:underline;}#yiv1466261196 span.yiv1466261196emailstyle171 {color:windowtext;}#yiv1466261196 span.yiv1466261196emailstyle181 {color:#1F497D;}#yiv1466261196 p.yiv1466261196msochpdefault1, #yiv1466261196 li.yiv1466261196msochpdefault1, #yiv1466261196 div.yiv1466261196msochpdefault1 {margin-right:0in;margin-left:0in;font-size:10.0pt;}#yiv1466261196 span.yiv1466261196BalloonTextChar {}#yiv1466261196 span.yiv1466261196EmailStyle33 {color:#1F497D;}#yiv1466261196 .yiv1466261196MsoChpDefault {font-size:10.0pt;} _filtered #yiv1466261196 {margin:1.0in 1.0in 1.0in 1.0in;}#yiv1466261196 div.yiv1466261196WordSection1 {}#yiv1466261196 _filtered #yiv1466261196 {} _filtered #yiv1466261196 {font-family:Symbol;} _filtered #yiv1466261196 {} _filtered #yiv1466261196 {font-family:Wingdings;} _filtered #yiv1466261196 {font-family:Wingdings;} _filtered #yiv1466261196 {font-family:Wingdings;} _filtered #yiv1466261196 {font-family:Wingdings;} _filtered #yiv1466261196 {font-family:Wingdings;} _filtered #yiv1466261196 {font-family:Wingdings;} _filtered #yiv1466261196 {font-family:Wingdings;}#yiv1466261196 ol {margin-bottom:0in;}#yiv1466261196 ul {margin-bottom:0in;}#yiv1466261196 Thanks Brent.    We installed QGIS 2.6 using standalone installer in windows OS, 32 bit with 4GB RAM. We are facing the below issue when Dissolving Vector layers using Grass commands. The processing log shows the below error,    |Could not load model watersheds.model|Error in algorithm name: saga:catchmentareaparallel ALGORITHM    The below error occurs while using Grass commands to dissolve vector layers, Oooops! The following output layers could not be open ·                    Dissolved layer: C:\Users\169099\AppData\Local\Temp\processing\5b5419e238924b5d87fc1e74254dec5b\output.shp The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithm Checking the log information might help you see why those layers were not created as expected This algorithm requires GRASS to be run. A test to check if GRASS is correctly installed and configured in your system has been performed, with the following result: GRASS seems to be correctly installed and configured    Can anyone please help us in resolving the above issue?    Regards, Padma Devi
Sent: Thursday, November 20, 2014 12:52 PM
To: Subramaniam, Padma Devi (Cognizant); qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] QGIS 2.6 installation    See: [Qgis-user] Why can I not find system requirements of QGIS
| [Qgis-user] Why can I not find system requirements of QGIS [Qgis-user] Why can I not find system requirements of QGIS Jonathan Moules jonathanmoules at warwickshire.gov.uk Fri Sep 7 04:11:36 PDT 2012  |  |
| View on lists.osgeo.org  | Preview by Yahoo  |  |
  so if you download the 32bit installer you should be fine with 4Gb.    I have run QGIS 2.6 on Linux on laptops with 2Gb memory quite easily. One test I tried was memory efficiency - a 200Mb shapefile loaded into QGIS raised QGIS memory use by 100Mb, about 1/2 the on disk data size. Another Open Source application I was trialling used 400Mb to do the same thing.    Brent Wood    From: "PadmaDevi.Subramaniam at cognizant.com" <PadmaDevi.Subramaniam at cognizant.com>
To: qgis-user at lists.osgeo.org
Sent: Thursday, November 20, 2014 8:08 PM
Subject: [Qgis-user] QGIS 2.6 installation    Hi Users,   Can you please confirm whether QGIS 2.6 can be installed in windows 32 bit OS with 4 GB RAM?   Regards, Padma Devi This e-mail and any files transmitted with it are for the sole use of the intended recipient(s) and may contain confidential and privileged information. If you are not the intended recipient(s), please reply to the sender and destroy all copies of the original message. Any unauthorized review, use, disclosure, dissemination, forwarding, printing or copying of this email, and/or any action taken in reliance on the contents of this e-mail is strictly prohibited and may be unlawful. Where permitted by applicable law, this e-mail and other e-mail communications sent to and from Cognizant e-mail addresses may be monitored.
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user This e-mail and any files transmitted with it are for the sole use of the intended recipient(s) and may contain confidential and privileged information. If you are not the intended recipient(s), please reply to the sender and destroy all copies of the original message. Any unauthorized review, use, disclosure, dissemination, forwarding, printing or copying of this email, and/or any action taken in reliance on the contents of this e-mail is strictly prohibited and may be unlawful. Where permitted by applicable law, this e-mail and other e-mail communications sent to and from Cognizant e-mail addresses may be monitored.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141120/845f69ca/attachment.html>
