[Qgis-user] Export categorized layers
    Matt Boyd
    mattslists at gmail.com
    Mon Nov 24 20:32:27 PST 2014
You can save the joined layer as a shapefile.
Then use the filter (right click on the layer > filter) to determine which
properties to select (you can even do a WHERE IS NOT NULL type thing I
think), it's just simple SQL type stuff there.
Then save the result as a shapefile.
Unless I don't understand what you're trying to do?
On Tue, Nov 25, 2014 at 3:08 PM, Matt Boyd <mattslists at gmail.com> wrote:
> So you have a layer created by joining 2 layers and you want to
> export/save the filtered  result?
> On 25/11/2014 2:22 am, "sudeten" <curt at slavniklabs.com> wrote:
>> I am using vector layers (one is shapefile and one is csv).  The csv gives
>> values for different shapes in the shapefile.  I have them colored as a
>> thematic map by using properties/style/categorized and choosing the
>> variable
>> that I need.  Now I need to export the map (just those shapes that have
>> values and are categorized - not the uncategorized shapes) to a shapefile
>> and or KML file.
>> This is very basic GIS stuff -- 1) create thematic map and 2) display
>> thematic map as a KML layer or a shapefile.  But I have found no way to do
>> this but many people asking the same question.
>> Any help here?
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Export-categorized-layers-tp5174544.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141125/834bceae/attachment.html>
