[Qgis-user] 2.6 very slow to render
Brett Adams
badams at spinifexgeophysics.com.au
Mon Nov 24 21:58:01 PST 2014
Checked out your suggestion Donovan.
As it’s a new installation I don’t think external plugins are loaded. (Guess that’s why I don’t have the qgis2 folder??? )
Data storage is small SHP files (100 points) and a series of raster images (300kB).
Same files that were being used in 1.8.
Brett
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saulteau Don
Sent: Tuesday, 25 November 2014 1:06 PM
To: qgis-user
Subject: Re: [Qgis-user] 2.6 very slow to render
One thing you can check for is if there is a faulty plugin causing the issue.
Try backing up your .qgis2 folder (ie, rename to .qgis2.backup)
Then relaunch QGIS 2.6 and test again.
What's the data storage format? Are they spatialite, postgis, shapefiles, etc?
Donovan
On Mon, Nov 24, 2014 at 9:14 PM, Brett Adams <badams at spinifexgeophysics.com.au> wrote:
Seems I spoke too soon.
Removing files from the Layer control takes an eternity
Tried uninstalling both 2.6 and 1.8 and reinstalling only 2.6 but this
doesn't seem to have helped.
ba
-----Original Message-----
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Brett Adams
Sent: Tuesday, 25 November 2014 10:09 AM
To: tech at wildintellect.com; qgis-user at lists.osgeo.org
Thanks Alex
That made a significant improvement. I can live with that.
brett
Try disabling/changing multi-threaded rendering. It may not work well on
your hardware.
Settings ->Options->Rendering
Thanks,
Alex
From: Alex Mandel [mailto:tech_dev at wildintellect.com]
Sent: Tuesday, 25 November 2014 9:59 AM
To: Brett Adams; qgis-user at lists.osgeo.org
On 11/24/2014 05:51 PM, Brett Adams wrote:
> Hi Folks,
> Just upgraded from 1.8 to 2.6.
> 2.6 is amazingly slow in the render control and rerendering compared
> to
1.8.
> Almost unusable.
> 1.8 runs perfect. Fast, efficient, no complaints.
> This has to be local to my machine, otherwise no one would be using 2.6.
> Any recommendations on what settings I can check? Running on W7-64.
> Thanks
> Brett Adams
> Spinifex Geophysics
> 0438 861 974
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141125/55a1e4fb/attachment.html>
