[Qgis-user] QGIS not running
Frank Sokolic sokolic at worldonline.co.za
Mon Nov 24 21:52:12 PST 2014
On 25/11/2014 06:21, Bernardo Santos wrote:
> Dear all,
> I do not know why, but my QGIS is not running. I am using QGIS 2.4
> Chugiak on Ubuntu 13.04.
> When I try to run QGIS, it returns a very long message that ends with:
> "src/core/qgsmessagelog.cpp: 45: (logMessage) 2014-11-25T02:18:02
> Complementos[0] Carregado MetaSearch Catalogue Client (pacote: MetaSearch)
> QGIS died on signal 11Could not attach to process.  If your uid matches
> the uid of the target
> process, check the setting of /proc/sys/kernel/yama/ptrace_scope, or try
> again as the root user.  For more details, see /etc/sysctl.d/10-ptrace.conf
> ptrace: Operação não permitida.
> No thread selected
> No stack.
> gdb returned 0
> Abortado (imagem do núcleo gravada)"
> What other information are needed to understand the problem?
> I have already tried to uninstall and re-install QGIS, but it did not work.
> Thanks in advance.
> Bernardo Niebuhr
I am having a similar problem with QGIS Master on Ubuntu 14.04 64 bit.
Since about a week ago I get the following error message:
Warning: loading of qgis translation failed
[/usr/share/qgis/i18n//qgis_en_GB]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_GB]
Warning: QGraphicsScene::addItem: item has already been added to this scene
ptrace: Operation not permitted.
No thread selected
No stack.
gdb returned 0
Aborted (core dumped)
I've also uninstalled and reinstalled QGIS but it still crashes on
startup. I've also tried running QGIS with the --noplugins switch but
this hasn't helped, nor does running it with sudo.
I wonder whether there has been a recent Ubuntu update that is causing a
problem on some machines?
Regards, Frank.
