[Qgis-user] 2.6 very slow to render and uninstalling 2.6 - Solution
    Brett Adams
    badams at spinifexgeophysics.com.au
    Tue Nov 25 19:13:32 PST 2014
I now have 2.6 running “normally” on W7-64
Previously everything done in in Layer control took an eternity to respond, especially if it involved raster images.    I’d been running 1.8 which worked perfect.
Solution was to uninstall and “clean” all QGIS files as follows;
1.      Uninstall 1.8 and 2.6  using windows uninstall
2.      Clean the Registry of all folders with “qgis” in the title.  I used Regedit which comes standard with windows.
3.      Delete the .qgis2 and .qgis folders from  “users”.  In my case these are located at C:\Users\BADAMS
4.      Restart machine
5.      Load 2.6
6.      Problem solved!!!
Interestingly when reloading 2.6  it tells me 2.6 is already loaded, so something remained during this process.  Didn’t seem to matter.
Thanks everyone for your help.
Brett
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Brett Adams
Sent: Tuesday, 25 November 2014 1:58 PM
To: 'Saulteau Don'; 'qgis-user'
Subject: Re: [Qgis-user] 2.6 very slow to render
Checked out your suggestion Donovan.
As it’s a new installation I don’t think external plugins are loaded.  (Guess that’s why I don’t have the qgis2 folder??? )
Data storage is small SHP files (100 points) and a series of raster images (300kB).
Same files that were being used in 1.8.
Brett
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Saulteau Don
Sent: Tuesday, 25 November 2014 1:06 PM
To: qgis-user
One thing you can check for is if there is a faulty plugin causing the issue.
Try backing up your .qgis2 folder (ie, rename to .qgis2.backup)
Then relaunch QGIS 2.6 and test again.
What's the data storage format? Are they spatialite, postgis, shapefiles, etc?
Donovan
On Mon, Nov 24, 2014 at 9:14 PM, Brett Adams <badams at spinifexgeophysics.com.au> wrote:
Seems I spoke too soon.
Removing files from the Layer control takes an eternity
Tried uninstalling both 2.6 and 1.8 and reinstalling only 2.6 but this
doesn't seem to have helped.
ba
-----Original Message-----
Sent: Tuesday, 25 November 2014 10:09 AM
To: tech at wildintellect.com; qgis-user at lists.osgeo.org
Thanks Alex
That made a significant improvement.  I can live with that.
brett
Try disabling/changing multi-threaded rendering. It may not work well on
your hardware.
Settings ->Options->Rendering
Thanks,
Alex
From: Alex Mandel [mailto:tech_dev at wildintellect.com]
Sent: Tuesday, 25 November 2014 9:59 AM
To: Brett Adams; qgis-user at lists.osgeo.org
On 11/24/2014 05:51 PM, Brett Adams wrote:
> Hi Folks,
> Just upgraded from 1.8 to 2.6.
> 2.6 is amazingly slow in the render control and rerendering compared
> to
1.8.
> Almost unusable.
> 1.8 runs perfect. Fast, efficient, no complaints.
> This has to be local to my machine, otherwise no one would be using 2.6.
> Any recommendations on what settings I can check?    Running on W7-64.
> Thanks
> Brett  Adams
> Spinifex Geophysics
> 0438 861 974
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141126/9b86bd2f/attachment.html>
