[Qgis-user] Qgis-user Digest, Vol 105, Issue 55
    Tim Paysen
    tpaysen at sbcglobal.net
    Tue Nov 25 16:42:58 PST 2014
Loading ESRI GDB as a directory
How in the world do you do that!!!
Tim Paysen
On Monday, November 24, 2014 12:02 PM, "qgis-user-request at lists.osgeo.org" <qgis-user-request at lists.osgeo.org> wrote:
Send Qgis-user mailing list submissions to
    qgis-user at lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
    http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Qgis-user digest..."
Today's Topics:
   1. Re: [Qgis user] Loading ESRI .mdb geodatabase
      (Martin Schneppm?ller)
   2. Re: Loading rectangular raster data in QGIS (Andre Joost)
   3. Re: Loading ESRI .mdb geodatabase (AntonioLocandro)
   4. Error executing the process r.const.full in QGIS 2.6
      (Andr?s Oca?a Carret?n)
   5. Re :  Export categorized layers (Junior)
Message: 1
Date: Mon, 24 Nov 2014 15:35:25 +0000
From: Martin Schneppm?ller <mstrms2000 at gmail.com>
To: Lester Anderson <arctica1963 at gmail.com>, qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] [Qgis user] Loading ESRI .mdb geodatabase
Message-ID:
    <CAC24e59vPODro0QykDkS-QAOvB-zheK+fshi3JBqxr2txvXuAw at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hi Lester.
Try it as directory not as database.
I use gdb files made with arcgis 10.2.2 and it works.
Lester Anderson <arctica1963 at gmail.com> schrieb am Mo., 24. Nov. 2014 15:52:
> Tried opening as file (ESRI Personal GeoDatabase), directory (ESRI
> FileGDB) and database  (ESRI Personal GeoDatabase) and it fails to
> recognise the file format on QGIS 2.6 64 bit.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141124/66e851b7/attachment-0001.html>
Message: 2
Date: Mon, 24 Nov 2014 16:35:18 +0100
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Loading rectangular raster data in QGIS
Message-ID: <m4vj8o$9ig$1 at ger.gmane.org>
Content-Type: text/plain; charset=windows-1252; format=flowed
Am 24.11.2014 um 12:39 schrieb Nicole Stoffels:
> Dear all,
> I am trying to load a raster file containing rectangular cells into
> QGIS. The header looks like this:
> ncols         97
> nrows         60
> xllcorner     276591.68
> yllcorner     5539072.48
> cellsize      58.198 , 87.623
> NODATA_value  -9999
I'm not sure which ratser format you ahve, but reading
http://www.gdal.org/frmt_various.html I assume GDAL expects DX and DY in
two lines instead of two values for CELLSIZE in one line. This could be
changed with a good text editor.
HTH,
Andr? Joost
Message: 3
Date: Mon, 24 Nov 2014 07:37:06 -0800 (PST)
From: AntonioLocandro <antoniolocandro at hotmail.com>
Subject: Re: [Qgis-user] Loading ESRI .mdb geodatabase
Message-ID: <1416843426283-5174558.post at n6.nabble.com>
Content-Type: text/plain; charset=us-ascii
If you are under windows, try installing the 32 bit version and see if that
opens the MS ACCESS MDB file, last time I checked 64 bit can't open it due
to some dependency that isn't met and I failed to ever get working, issue
was filed back then not sure what happened as I lost track of it
View this message in context: http://osgeo-org.1560.x6.nabble.com/Loading-ESRI-mdb-geodatabase-tp5174462p5174558.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
Message: 4
Date: Mon, 24 Nov 2014 18:21:40 +0000 (UTC)
From: Andr?s Oca?a Carret?n <andresocaac at yahoo.es>
To: "Qgis-user at lists.osgeo.org" <Qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Error executing the process r.const.full in QGIS
    2.6
Message-ID:
    <2134473074.427949.1416853300331.JavaMail.yahoo at jws11103.mail.ir2.yahoo.com>
  Good afternoon!
I'm trying to work with the new process r.const.full included in the latest version of QGIS 2.6, but I get an error message.
I think the problem may be in the start point, so I tried both raster files as vector files. In support of the process indicates that you can use these formats and another one, which would introduce the coordinates in the command line, but no command line appears.
The error message I get is the following:
"Oooops! The following output layers could not be open
   - Cumulative cost: C:\Users\Andres\AppData\Local\Temp\processing\5c134de287db49db8fee7a0f94640c76\output.tif
The above files could not be opened, which probably indicates that they were not correctly produced by the executed algorithmChecking the log information might help you see why those layers were not created as expectedThis algorithm requires GRASS to be run. A test to check if GRASS is correctly installed and configured in your system has been performed, with the following result:GRASS seems to be correctly installed and configured"
I would appreciate someone to help me on where the problem may be that the process does not work.
Thank you
Best Regards
Andres Oca?a
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141124/c1c2490d/attachment-0001.html>
Message: 5
Date: Mon, 24 Nov 2014 19:32:14 +0100
To: "sudeten" <curt at slavniklabs.com>,qgis-user at lists.osgeo.org
Subject: [Qgis-user] Re :  Export categorized layers
Message-ID: <547379af.885eb40a.66e1.ffffcb47 at mx.google.com>
Hi Sudeten,
What about a right click on layer name   and "Save As..."?
You may need to select features before, if you don't want all the current features of the layer in your kml.
Envoy? depuis mon HTC
----- Reply message -----
De : "sudeten" <curt at slavniklabs.com>
Pour?: <qgis-user at lists.osgeo.org>
Objet : [Qgis-user] Export categorized layers
Date : lun., nov. 24, 2014 16:23
I am using vector layers (one is shapefile and one is csv).  The csv gives
values for different shapes in the shapefile.  I have them colored as a
thematic map by using properties/style/categorized and choosing the variable
that I need.  Now I need to export the map (just those shapes that have
values and are categorized - not the uncategorized shapes) to a shapefile
and or KML file.
This is very basic GIS stuff -- 1) create thematic map and 2) display
thematic map as a KML layer or a shapefile.  But I have found no way to do
this but many people asking the same question.
Any help here?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Export-categorized-layers-tp5174545.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141124/4ddd37c2/attachment-0001.html>
End of Qgis-user Digest, Vol 105, Issue 55
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141125/76de1869/attachment.html>
