[Qgis-user] POint to polygon
    Goyo
    goyodiaz at gmail.com
    Wed Nov 26 10:02:22 PST 2014
Hello Joris,
there is an old feature request about this:
https://bugs.launchpad.net/points2one/+bug/772077
It never reached high priority because the easy workaround (plus I
usually get the points in spreadsheets so the first step is
unnecessary and the second one is trivial for me), but I guess it is
about time to fix it. I'll try to find a slot to work on it in the
next weeks.
Goyo
2014-11-26 9:51 GMT+01:00 Joris Hintjens <jorishin at gmail.com>:
> I found a workaround:
> export the layer to a csv with geocoordinates (through mmqgis plugin)
> edited the csv so that the IDs are in the desired order
> import the cvs as new layer and have this polygonized with the Points2one
> plugin.
> quite a hassle, but it works.
> thanks
> Joris
> Op 25-nov.-2014, om 20:50 heeft Ravi Mehta <rrm364 at gmail.com> het volgende
> geschreven:
> How is your data stored right now?
> - Ravi Mehta
> On Tue, Nov 25, 2014 at 10:21 AM, Joris Hintjens <jorishin at gmail.com> wrote:
>> I feel like a fool. So simple, but I can’t find the right tool to convert
>> a point layer into a polygon without the hassle of exporting to csv and
>> re-importing as a polygon. the Plugin POint2one does not allow me to change
>> the merge-order. Any suggestions are welcome.
>> Greest
>> Joris
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
