[Qgis-user] Lizmap - can't insert&update data in PostGis Views
kimaidou
kimaidou at gmail.com
Wed Nov 26 10:03:45 PST 2014
Hi Pedro
Sorry for the late answer. I will answer the issue on github too.
You are right, you should normally be able to edit your view in Lizmap too.
I doubt this is a user problem, as Lizmap read the datasource in QGIS for
each edition layer and so use the same user.
I will have a look at the error reported in github issue. Could you report
there [1] version of QGIS do you use as desktop and server ?
Regards
Michael
[1] https://github.com/3liz/lizmap-web-client/issues/108
2014-11-26 13:54 GMT+01:00 Pedro <pedro.ferro at gmail.com>:
> Yes, the user to access the Postgresql is the same in QGIS and Lizmap.
> http://osgeo-org.1560.x6.nabble.com/Lizmap-can-t-insert-update-data-in-PostGis-Views-tp5174737p5175038.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141126/8d07261c/attachment.html>
