[Qgis-user] Lizmap - can't insert&update data in PostGis Views
Pedro
pedro.ferro at gmail.com
Thu Nov 27 03:11:00 PST 2014
kimaidou wrote
> Hi Pedro
> Sorry for the late answer. I will answer the issue on github too.
> You are right, you should normally be able to edit your view in Lizmap
> too.
> I doubt this is a user problem, as Lizmap read the datasource in QGIS for
> each edition layer and so use the same user.
> I will have a look at the error reported in github issue. Could you report
> there
> [1] version of QGIS do you use as desktop and server ?
> Regards
> Michael
Hi Michael,
Thanks for your reply.
I've update the github issue with the information you ask for (QGIS Sever:
2.6.0.1 ; QGIS Desktop: 2.6 and 2.4 ).
Few days ago I've opened another github issue (#107): when identifying a
feature, the form don't have the configuration that we define at QGIS |Edit
Widget but with the edit form it have the same configuration define in QGIS
| Edit Widget (like it should).
I take this opportunity to mention other issues that seems to me are not
with a "fine tuning" at Lizmap (its more some kind of improvement tasks):
1. It would be helpful if, at Lizmap Plugin, we can define which is the Base
Layer we want to see at entrance on Lizmap Web client (in my case I would
like to make the empty base layer the layer of entrance in the lizmap web)
2. If you have a Google Base Layer it change the font in the identify form.
<http://osgeo-org.1560.x6.nabble.com/file/n5175256/base_layers.png>
Thank you for your time,
Pedro
View this message in context: http://osgeo-org.1560.x6.nabble.com/Lizmap-can-t-insert-update-data-in-PostGis-Views-tp5174737p5175256.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
