[Qgis-user] Add WMS in QGIS gives an error with Map request failed [error:Host http not found url:http://http//
Matthias Kuhn matthias.kuhn at gmx.ch
Sun Nov 30 05:52:24 PST 2014
Did you try to omit the inital http:// and only enter
[IP]:11188/mapviewer/wms
Matthias
On 11/30/2014 02:20 PM, Strunck, Alexander GIZ PS wrote:
> Thank you for your response, but the problem does not change.
> Map request failed [error:Host http not found url:http://http//[IP]/:11188/mapviewer/wms?SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&BBOX=-180,-90,180,81.45996592844974771&SRS=EPSG:4326&WIDTH=1120&HEIGHT=533&LAYERS=GT_BLOCKS_MB&STYLES=&FORMAT=image/png&DPI=120&MAP_RESOLUTION=120&FORMAT_OPTIONS=dpi:120&TRANSPARENT=TRUE]
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jukka Rahkonen
> Sent: Sunday, November 30, 2014 13:28
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Add WMS in QGIS gives an error with Map request failed [error:Host http not found url:http://http//
> Strunck, Alexander GIZ PS <alexander.strunck at ...> writes:
>> http://http//
>> and the part with the port
>> /:11188
>> How can I fix the problem???
>> Thank You
> Hi,
> I would try if it works by checking "Ignore GetMap URL reported in capabilities" from the connection details of that WMS server.
> -Jukka Rahkonen-
> Qgis-user mailing list
> ________________________________
> Deutsche Gesellschaft fuer Internationale Zusammenarbeit (GIZ) GmbH;
> Sitz der Gesellschaft Bonn und Eschborn/Registered offices Bonn and Eschborn, Germany;
> Registergericht/Registered at Amtsgericht Bonn, Germany; Eintragungs-Nr./Registration no. HRB 18384 und/and Amtsgericht Frankfurt am Main, Germany; Eintragungs-Nr./Registration no. HRB 12394;
> USt-IdNr./VAT ID no. DE 113891176;
> Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: Dr. Friedrich Kitschelt, Staatssekretaer/State Secretary;
> Vorstand/Management Board: Tanja Goenner (Vorstandssprecherin/Chair of the Management Board), Dr. Christoph Beier (Stellv. Vorstandssprecher/Vice-Chair of the Management Board), Dr. Hans-Joachim Preuss, Cornelia Richter
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141130/a9bcd1a5/attachment.html>
