[Qgis-user] How to calculate the transformation parameters for the QGIS Affine Plugin
Germán Carrillo
carrillo.german at gmail.com
Tue Oct 7 12:18:39 PDT 2014
Just in case you have R within reach, have a look at the post "Similarity
and affine transformations in R" [1], which explains how to use my R plugin
"vec2dtransf" to perform affine transformations.
Regards,
Germán
[1]
http://geotux.tuxfamily.org/index.php/en/geo-blogs/item/302-affine-and-similarity-transformations-in-r
[2] http://cran.r-project.org/web/packages/vec2dtransf/index.html
2014-10-07 13:59 GMT-05:00 Siki Zoltan <siki at agt.bme.hu>:
> Hello Marcel,
> to calculate affine transformation parameters you must have at least 3
> points in both coordinate systems.
> LV95_y = Y0 + a * local_y + b * local_x
> LV95_x = X0 + c * local_x + d * local_y
> If you set up the equations for the three points, you get to linear
> equation systems, one for Y0, a, b unknowns, and another fo X0, c, d
> unknowns.
> It is highly recommended to use more points and least squares estimation
> for the parameters.
> Best regards,
> Zoltan
> On Tue, 7 Oct 2014, Marcel Stadelmann wrote:
> Hi,
>> I would like to make an affine transformation with a vector layer shape
>> file, using the Affine Plugin. I know from two points the correct
>> coordinates:
>> local_y local_x LV95_y LV95_x
>> 9.065056 7.70714 2753308.44 1166381.26
>> 9.065056 -5.085236 2753295.68 1166391.31
>> How can I calculate the transformation parameters?
>> Marcel
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
|\__
(:>__)(
Soluciones Geoinformáticas Libres
http://twitter.com/GeoTux2
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141007/6611740a/attachment.html>
